View Poll Results: A poll
do the manual conversion
40.00%
its too much money dont do it
40.00%
keep the automatic tranny
20.00%
Voters: 5. You may not vote on this poll
what should i do if i loose my tranny?
Old Feb 8, 2007 | 01:27 AM
Sp33d07's Avatar
Default what should i do if i loose my tranny?
i have 2001 tip a4, have some mods and looking to put more, i know the automatic tranny does not hold power like the manual does. what should i do if i loose my transmission? anyone has done manuall conversen, and if i buy a manual tranny used will it be cheaper? thank you i cant sell my car because then i have to deal with a stock car again.. dont wanna start over...+ i luv my car
Old Feb 8, 2007 | 01:37 AM
onepoint8tee's Avatar
Default RE: what should i do if i loose my tranny?
Just get a level10 tq converter andvalve body upgrade. It will cost the least and youll be able to use more power than any manual tranny could handle.
Old Feb 8, 2007 | 01:40 AM
Sp33d07's Avatar
where can i get it done? i never herd of this and howmuch approx. it will be for both and what are the purpose of them. thank you for being helpful
Old Feb 8, 2007 | 01:43 AM
Cameron's Avatar
I noticed you sig says you still need to upgrade your exhaust - tip exhaust and 5-spd exhaust is different. You'd also need a new ECU for the swap.
You can easily swap the evo intake over to a new car, same with the wheels, 710n, boost gauge, and its easy to paint calipers. That means that if you were to buy a new car (5-spd) if your tranny craps out, you would loose the mintex pads - which are a wear item,m3 spoiler, and tint.
I could see a swap if you had some serious modifications already installed, but at this point I'd say its more worth it to put the car back to stock and sell it. Maybe you could work out a deal with APR where they unflash/unchip your ECU and then they reflash/rechip the new car as soon as you get it.
Old Feb 8, 2007 | 01:56 AM
http://levelten.com/
If it were me, id sell it and find a manual. No point/cost effectivnessin converting and not much fun having an automatic with all that power, even if the tranny CAN handle it with an upgrade.
Old Feb 8, 2007 | 02:02 AM
Cameron's Avatar
Not to mention the parasitic drag of the automatic transmission...
A manual tranny can hold plenty of power when its built right, but you will eat clutches.
Old Feb 8, 2007 | 02:14 AM
tractioncontrol's Avatar
Pull the tranny before it breaks and have someone cryo treat the gears. The valve body upgrade is the best automatic tranny upgade I have ever felt....but it was in a lightning.
texasboy21
Jan 8, 2017 01:15 AM
Nemick
Sep 11, 2012 05:33 PM
miamiphi
Jun 14, 2007 06:45 PM
DeusInvictus
Feb 17, 2007 08:08 PM
duburban
Dec 29, 2006 06:41 PM
