what's up with my mpg?? getting only 15!
Old May 5, 2006 | 05:13 PM
lilbrownindian's Avatar
Default RE: what's up with my mpg?? getting only 15!
good god that is rather low..
Old May 5, 2006 | 05:15 PM
techbod's Avatar
ORIGINAL: Jestnomen
ORIGINAL: avant80@2.6
2002 A4 3.0QM that's why
huh?
huh its a 3 liter so what do you expect,
now we know its a 1.8 it definitely has a problem so codes need to be checked it could be the cat on its way out
Old May 5, 2006 | 05:16 PM
miabhai_freaked's Avatar
hmmmm....that's what i said...did any of u guys try putting in those fuel injector cleaners that
you can put in the gas tank after filling it? also someone told me that mixing 2 gas types like a 89 and
a 91 increases the gas milage...is there any truth to that?
Old May 5, 2006 | 05:19 PM
apercele79's Avatar
as far as i know, the gas cleaner goes in when the tank is very close to empty, not after filling the tank
and as far as mixing it...mix 91 and 93 if anything
anything under 91 aint touching this gas tank...
onepoint8tee's Avatar
What kind of gas do you put in it??
Could be old/lazy pre cat 02 sensors like jest said, they dont normaly set off a CEL until they are completely dead or lose the signal.. I replaced pre cat 02 sensors on my nissan at 117k miles even thought there was no CEL and noticed a huge gain in mpg. Deffinately run a few doses of some injector cleaner.. Check air filter... Spark plugs and any other obvious stuff i didnt mention.
techbod's Avatar
a 91 increases the gas mileage...is there any truth to that?
absolutely not
Old May 5, 2006 | 05:24 PM
ORIGINAL: onepoint8tee
well...i got new spark plugs/timing belts/accessory belts less than 5000 miles ago...so that should'nt be a problem...
it is hard to replace a pre cat sensor? and any idea how much it costs? i'll go down to autozone and check it out,,,
Old May 5, 2006 | 05:26 PM
  #18
techbod's Avatar
a little cheat here, remove both o2 sensors from the rear "next to the cat " tie them up out of the way and blank the pipe obviously and the system cant log equal data because that's how they work then blank the EGR valve
Old May 5, 2006 | 05:31 PM
  #19
hmmm...excuse my ignorance...but i have no clue what you meant by that...maybe could you
explain more in layman's terms?
Old May 5, 2006 | 05:39 PM
  #20
Thats a sure way to kill the cat isnt it??? by "blank the cat" do you mean "block"?
