Wheel lug shank size
Old Mar 6, 2006 | 12:53 AM
A4_Spooler's Avatar
Default Wheel lug shank size
I just bought some wheels for my 2001 1.8t and am in search of some lug nuts since the factory black ones arent quite cutting it. Anyways, lookin around on ebay i saw there are 4 different shank sizes - 23mm, 24mm, 27mm, and 30mm. Anyone know why there is a difference in sizes and if it would make an impact as far as tightness and fitment for the wheels\lugnuts? Also along with the shank sizes, there was another size involved, the thread sizes, 12x1.5 or 14x1.5, does anyone have any idea which thread sizes are for which audi? Any help would be GREATLY appreciated..... here is the link i was looking at if it isn't blocked.....
http://search.ebay.com/audi-lug-nut_...Z1QQsofocusZbs
Old Mar 6, 2006 | 04:11 PM
Jestnomen's Avatar
6th Gear
Default RE: Wheel lug shank size
Contact the supplier of the wheel.
Old Mar 8, 2006 | 01:33 AM
dankhound's Avatar
Also make sure the wheel fits tight on the hub. Audi wheels are hub centric and need to fit tight around the hub. If the wheel doenst fit tight onto the hub on your car you need to get the proper spacer for the wheel to fit tight on the hub. That should also be availble from the wheel manufacturer. Be sure to use the wheel manufacters specified hardware as mentioned above.
Old Mar 8, 2006 | 01:43 AM
black991.8tq's Avatar
u just need hub rings for audi, the wheel size is the same, its the hubs that are different from car to car. you might wanna search for audi wheel studs(lugnut bolts)on ebal
mystrodo
Sep 2, 2009 09:41 AM
awdorifto
Sep 26, 2007 05:09 PM
Avant1.8t
Jul 11, 2007 03:11 PM
A4 Guy
Sep 11, 2006 01:21 PM
Agro
Jun 11, 2006 11:30 AM
