Wheel Size?
Wait till you get the wheels - then using a ruler, hold it on the fender - measure the distance from the sidewall to the ruler and then order that size spacer. then it will look the best. you will also need to order longer lug bolts acordingly to how thick of a spacer you get.
make sure you calculate out how much your going to be spending extra to make these work and see if its worth your time.
http://forums.vwvortex.com/zerothread?id=3316897
^^ those are the wheels.
im just nervous about rubbing issues. is any one eles running a 40 offset on their car?
