Wheel Size?
Old Jul 11, 2007 | 10:27 AM
Avant1.8t's Avatar
Default Wheel Size?
Online tire stores are telling me to go with a 18X8 5x112 ET 35
buttt, i found a good deal and was wondering if there will fit ok?
18X8 Axis Supermesh 5X112 ET 40
Old Jul 11, 2007 | 10:33 AM
akielb's Avatar
Default RE: Wheel Size?
that will fit 5mm closer to the inside of the body
Old Jul 11, 2007 | 10:42 AM
Avant1.8t's Avatar
so with a set of spacers i should be fine?
Old Jul 11, 2007 | 10:49 AM
akielb's Avatar
Wait till you get the wheels - then using a ruler, hold it on the fender - measure the distance from the sidewall to the ruler and then order that size spacer. then it will look the best. you will also need to order longer lug bolts acordingly to how thick of a spacer you get.
make sure you calculate out how much your going to be spending extra to make these work and see if its worth your time.
Old Jul 11, 2007 | 03:11 PM
Avant1.8t's Avatar
http://forums.vwvortex.com/zerothread?id=3316897
^^ those are the wheels.
im just nervous about rubbing issues. is any one eles running a 40 offset on their car?
mystrodo
Sep 2, 2009 09:41 AM
awdorifto
Sep 26, 2007 05:09 PM
A4 Guy
Sep 11, 2006 01:21 PM
TexasAudi
Dec 25, 2005 04:41 AM
norcaltrojan
Jul 25, 2004 06:50 PM
