wheel spacers on stock wheels
Old Oct 18, 2005 | 03:38 PM
BFlan2001's Avatar
Default wheel spacers on stock wheels
would this be ok to do? i'm considering getting some 12mm wheel spacers, just to bring the wheels out to match up better with the fender. what would be the downfalls of doing this?
Old Oct 18, 2005 | 07:48 PM
skidplatexa4's Avatar
Default RE: wheel spacers on stock wheels
My RS4's have an offset of 45mm instead of the stock 35mm. I don't see or feel any problems with my car with the different offset.
Old Oct 18, 2005 | 08:59 PM
sandman's Avatar
if you are lowered you could see some fender rub.
Old Oct 18, 2005 | 10:01 PM
brent07's Avatar
let me know how that works out for you and how much it costed. i've been thinking about the same thing.
Old Oct 18, 2005 | 10:33 PM
4dot's Avatar
i wouldn't suggest spacers on our cars for a couple of reasons:
1) our cars are a bit heavier than normal, and the spacers will allow a wider wheelbase. the spacers will not be welded together with the rims so that leaves room for the spacers to shift under the cars weight (heavy turns, hard breaking, etc..), which over time, could result in poor alignment or worse.
2)the wheels on that car were designed to have a 35mm offset. if you add spacers you are essentially making the wheel with a smaller offset, perform the job of a wider wheel (bigger offset). this could again cause alignment or tire wear problems in the future.
my suggestion is either get some wheels with the offset your looking for, or 'luv the ones yer with' ------- otherwise you are asking for trouble.[sm=signs003.gif]
Old Oct 18, 2005 | 10:36 PM
flyboy's Avatar
just get the ones they sell on ECS they are from H&R and are made well.
Risky_Jim
Nov 9, 2010 01:34 PM
mr peepers
May 22, 2009 12:24 AM
jaymac
Apr 26, 2009 11:04 AM
hoestess
Oct 29, 2008 01:27 AM
BLRzAUDI
Apr 6, 2007 10:34 AM
