When i turn my alarm on/off, only one corner light flashes...?
Old Sep 22, 2004 | 04:52 AM
chriscollins's Avatar
Default When i turn my alarm on/off, only one corner light flashes...?
Hey all,
So another question for the masses.
When i push my alarm button (after market alarm), only one side (driver side) lights up. The front corner marker flashes, then stays on until it dims away. The rear taillight on the same side does the same. The interior light turns on as well then dims as usual for an alarm.
Is there a way to make both sides turn on when i do this? I'm sick of the 'dude, you're lights on the passenger side are out...' comments. Is this standard? If so, i want it to be not-standard.
Help me make both sides light up when i press the alarm button! Thanks all.
'chris
Old Sep 22, 2004 | 05:46 PM
David_K's Avatar
Default RE: When i turn my alarm on/off, only one corner light flashes...?
Move this to the general forum.
Check your fuses/bulbs.
Old Sep 23, 2004 | 02:41 AM
SlimChriz's Avatar
check your blinkers to see if its the bulb.
if not like you said its aftermarket so we cant help you unless someone has the same system which you didnt list...
donsajid
Apr 25, 2013 12:51 PM
PluschakovP
Jan 20, 2009 09:51 PM
wutafobbb
Apr 15, 2008 10:23 PM
batanguenio
Sep 26, 2006 07:07 AM
foulkrj
Jun 19, 2006 12:54 AM
