who has a bentley?
Old Feb 26, 2006 | 02:05 AM
trailboss's Avatar
Default RE: who has a bentley?
ORIGINAL: Jestnomen
Have you read the DIY timing belt change tutorials on Audiworld?
Dont think many people search or plan things before they do them, I can think of at least 3-4 diy TB replacements.
Old Feb 26, 2006 | 03:14 AM
mjvss21's Avatar
ORIGINAL: trailboss
ORIGINAL: Jestnomen
wow way to assume something that is totally not true, i know about the ones on audiworld infact that is what i used. you really think i just decided to do a timing belt with out "searching or plaing" first? there were just a few things missing, leading me asking for help, but apparently no one likes to help people out on here so thats cool to.
Old Feb 26, 2006 | 10:13 AM
david9999's Avatar
YGM
Tightening torques
Component
Tightening torque
Belt pulley to power steering pump
25 Nm (18 ft lb)
Power steering pump to mounting bracket for generator, power steering pump and viscous fan
25 Nm (18 ft lb)
1 - Bolt
10 Nm (7 ft lb)
2 - Bolt
10 Nm (7 ft lb)
3 - Bolt
10 Nm (7 ft lb)
4 - Bolt
20 Nm (15 ft lb)
5 - Upper toothed belt cover
To remove, unbolt ribbed belt tensioner
When installing, carefully hook into lower toothed belt cover
6 - Toothed belt
Before removing, note direction of rotation using chalk or felt-tip marker
Check for wear
Removing Page 13-29
Installing (adjusting valve timing ) Page 13-32
7 - Bolt for tensioner
25 Nm (18 ft lb)
8 - Nut
10 Nm (7 ft lb)
9 - Washer
10 - Bolt
65 Nm (48 ft lb)
Use 3036 retainer for loosening and tightening
11 - Washer
12 - Camshaft gear
For exhaust camshaft
For removing and installing, remove toothed belt Page 13-29
Installation position Fig. 1
13 - Tensioner
14 - Connecting bolt
25 Nm (18 ft lb)
For tensioner
15 - Rear toothed belt cover
16 - Bolt
20 Nm (15 ft lb)
17 - Intermediate shaft gear
18 - Washer
19 - Toothed belt gear for crankshaft
Contact surface between toothed belt gear and crankshaft must be free of oil
Installation only possible in one position
20 - Bolt for toothed belt gear for crankshaft
Always replace
90 Nm (66 ft lb) + additional 1/4 turn (90)
Do not oil
Use 3099 retainer for loosening or tightening
Attach 3099 retainer Page 13-39
To secure retainer, remove torque support bracket Page 17-2 , item 5
21 - Bolt
65 Nm (48 ft lb)
Use 3036 retainer when loosening or tightening
22 - Toothed belt tensioner
23 - Bolt
10 Nm (7 ft lb)
24 - Idler pulley
25 - Bolt
25 Nm (18 ft lb)
26 - Lower toothed belt cover
To remove, remove vibration damper
[IMG]local://upfiles/1947/3C6440EDA3314F618A1157C2A95982DF.gif[/IMG]
[IMG]local://upfiles/1947/3E7DCAB8946D44F5B72F89B00B2B22B5.gif[/IMG]
kayakman13
Dec 9, 2009 08:47 PM
joshuo
Feb 21, 2009 11:50 AM
sik_A4
Oct 2, 2006 05:02 AM
chuckievi
Aug 31, 2006 04:02 AM
onepoint8tee
Feb 11, 2006 04:50 PM
