Who has an Indash DVD?
I have one as well. The wiring harness that you buy for it will work and make your front speakers play but the back ones won't. You have to run new speaker wire from the deck/wiring harness rear speaker output to your speakers. I had to do that in my car. It took about 2 hours or so to get everything up and running right but it was worth it. If you need an more help feel free to PM me or something.
Josh
Josh
you will need to bypass the bose amp inorder to use an aftermarket deck and still the speakers will sound terrible. which is why someone suggested changing all your speakers out as well, since they do run at a diffrent ohm then aftermarket one and aftermarket headunits
ORIGINAL: deph
Josh
ORIGINAL: ThePaintballGuy
Josh
Josh
go to
www.millionbuy.com -> they should have the harnesses you need, also good deals on moniters that is where i buy all my audio stuff.
