Who's running Water/Meth injection?
Old Nov 19, 2007 | 04:40 PM
pyropenguin's Avatar
Default Who's running Water/Meth injection?
So right now I'm just contemplating the future of my A4, and w/m injection popped into my head. I've looked into it a little before, but who's using it on their A4 with the k03?
What are the pros?
What are the cons?
How often do you have to refill?
What w/m injection kit are you running?
What are your mods?
I'm planning on running it because I'm cheap, and it'll be nice to be able to stay in the lower class for auto-x.
Thanks,
Kyle
Old Nov 19, 2007 | 04:52 PM
Audi_Skydiver's Avatar
Default RE: Who's running Water/Meth injection?
I was looking into this as well. I Had the same questions and there is a post somewhere around here that answers that. I will try and find it.
Josh
Old Nov 19, 2007 | 04:54 PM
cincyTT's Avatar
I'm make believe
What are the pros? Lower iat, increased octane rating on 93 (moves it to over 100), cleans cylinders, andreduces knock
What are the cons? The install, not hard, but needs installed
How often do you have to refill? Depends on amount injected (depends on hp level), how you driveand size of bottle used. You should go atleast a full tank with a decent sized tank
What w/m injection kit are you running? Only 2 worth running are Snow performance stg2 and devils own stage 2
The only downside of this for you is that you have a '98 which you cant use lemmingwinks on (to increase timing). But you will however get to use a 100+ octane race file on pump gas along with increased psi daily.
Old Nov 19, 2007 | 04:58 PM
Here is a good thread:
https://www.audiforums.com/m_688170/tm.htm
Josh
Old Nov 19, 2007 | 04:59 PM
Cincy, how hard is it to use lemmingwinks? Is there any good sites on how to use it?
Josh
Old Nov 19, 2007 | 05:05 PM
ORIGINAL: ThePaintballGuy
Josh
You have the same engine as me, so you can't use it either!
Here's my post on audizine, lots of good information in there, I was just curious if anyone had some more info here. http://audizine.com/forum/showthread.php?t=172384
Cincy maybe you can help me with this, Why is the Snow Performance Stg 2 kit $90 more than the DevilsOwn kit? They're both progressive, does the Devils Own kit not get the boost reading from the MAF? I see the Snow Performance kit includes a tank, but I wont use that anyways, and that can't be the only thing different for the $90 difference.
cincyTT's Avatar
I'm make believe
There are some good write ups on Vortex about it and a wika page that was very imformative aswell, but i cant seem to find that page again [:@]
But to my understanding is that Lemmi/Unisettings doest work on pre2k cars. So you need to have a race file or water meth program installed in the ecu like so
In the B5'er
Old Nov 19, 2007 | 05:08 PM
Bigrigatoni's Avatar
I had problems communicating with my ECU using Limmiwinks. Cincy recommended Unisettings and it has worked great for me! very easy to use....Ciny is FTW!!
http://www.unitronic.ca/uni/index.ph...&Itemid=58
Old Nov 19, 2007 | 05:09 PM
I'll just be running it on GIAC k03 software, so I would just get a 100oct program and 91 oct program, correct?
Old Nov 19, 2007 | 05:11 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: pyropenguin
Higher psi capable pump and better name. You can run a map or maf based kit for both also. The Snow kit is cheaper at USralleyteam.com ($390 and other options available).
