Why is 21PSi diffrent on a T3T4 then a KKK?
Old Feb 13, 2007 | 09:36 PM
Lazer Viking's Avatar
Default RE: Why is 21PSi diffrent on a T3T4 then a KKK?
explaination should seriously go in your sig
fxcking a+ for explaination
Old Feb 13, 2007 | 11:12 PM
new2me's Avatar
ORIGINAL: Lazer Viking
thanks everyone
I was going to but dont know how to get the quote in there.
Old Feb 13, 2007 | 11:17 PM
[quote ] [/quote]
Old Feb 13, 2007 | 11:24 PM
new2me's Avatar
Its says i have to many characters
Old Feb 13, 2007 | 11:26 PM
if you take 2 straws 1 is tiny the other is larger (like mc-d's) If you suck with the same amount of forcewith both straws the larger straw will give you more liquid but the force is the same.
Old Feb 14, 2007 | 02:49 AM
AudiCross's Avatar
erm, sorry to be a kill joy but that explination isnt exactally correct. a k03 putting out 20 psi at 3.5k rpm will give the exact same HP as a T3/T4 putting out 20 psi at 3.5k rpm. the reason you get a crap load more power is that it holds that boost till the end. the straw is partly correct, but no matter howq big ur straw is, 20 psi at a given RPM is still 20 psi. the bigger turbine gives it the ability to keep that pressure longer. so again, 20 psi at any RPM will give u the same power no matter what it pushing it in. its just what RPM that boost is schieved at.
Old Feb 14, 2007 | 03:03 AM
StepUpProductions's Avatar
^^ agree with that
Old Feb 15, 2007 | 05:16 PM
  #18
kmatsen1's Avatar
i think we are getting close but not exactly correct yet. 20 psi in a manifold regardless of what turbo you have is the same amount of air IN THE MANIFOLD. BUT, if you increase the flow of air out of the manifold you need to increase the flow into it to keep a constant pressure. So even though the pressure is the same, the cfh (cubic feet per hour) of air going through it is different.
Old Feb 15, 2007 | 05:28 PM
  #19
kmatsen1's Avatar
woops, i might have been ahead of myself. engineers do that sometimes. so what actually controls the flow of air into the manifold is the speed at which it leaves. what controls the speed of air leaving the manifold is the volume it has to go into next. that would be the volume in the cylinders. so if the timing or compression ratio are not changed the amount of air into the cylinder is the same for either turbo. BUT when you start getting into high revs, the cfh of air goes up since the valves are opening and closing more times per minute.
so, a bigger turbo that produces more cfh of air can keep the boost at 20 psi longer.
so in the end, all i did was explain Audicross's answer in more detail. sorry Audicross
Old Feb 16, 2007 | 01:33 AM
  #20
david9999's Avatar
Right. The Chipped k03 runs out of steam at 5K and the pressure and CFM drop. The larger turbo pushes more CFM and is able to keep the pressure up higher in the RPM range.
