wierd noise?
Old Nov 21, 2005 | 03:35 AM
dan908's Avatar
Default RE: wierd noise?
Like damaging bad on the front because your snub mount is mounted below your radiator and at the front and yeah.
Open hood, look down, there is a bar between the radiator and the ground, it has a piece of metal and a snub mount that holds your engine from the front
Old Nov 21, 2005 | 03:38 AM
PandaXpress's Avatar
this will help u
http://goapr.com/Audi/support/snub_mount.pdf locate it
Old Nov 21, 2005 | 03:40 AM
dan908's Avatar
Wow, just uh don't take the car apart unless you have to.
I love the A6, Everything is so open and easy to find.
Old Nov 21, 2005 | 04:01 AM
socalaudi's Avatar
I just checked the snub mount and it seems to be fine. The bushing is still in tact along with the bolts holding it in place.
Old Nov 21, 2005 | 04:03 AM
socalaudi's Avatar
Thanks for the step by step.
Old Nov 21, 2005 | 06:15 AM
BFlan2001's Avatar
next thing to check would be the tranny mounts. check out this writeup to see where they are.
http://mtdiblasi.home.comcast.net/allroad/
Old Nov 21, 2005 | 07:03 AM
socalaudi's Avatar
thanks alot for the write up.
Old Nov 26, 2005 | 05:24 AM
  #18
haveaseat's Avatar
Member
check what the germans like to call the "clutch bushing"...basically a u-joint made of rubber at the back of the tranny on the drive shaft
fltt
Jan 8, 2011 12:11 AM
2000_2.7t
Sep 8, 2008 03:08 PM
jduplooy
Jul 3, 2007 01:43 PM
memzback
Jan 23, 2007 01:03 AM
tooxtreme8813
Jul 18, 2006 03:59 AM
