wierd noise & feeling coming from up front
Old Jun 26, 2005 | 11:43 PM
shadyr78's Avatar
Default wierd noise & feeling coming from up front
it sounds and feels like i'm running over a bunch of road reflectors. this happens both in city streets and on the highways. any ideas?
Old Jun 27, 2005 | 07:46 AM
AWDaholic's Avatar
Senior Administrator
Default RE: wierd noise & feeling coming from up front
We're gonna need more info to be of any help to you. Year, model, quattro(?), approx mileage, road speed at onset of symptoms, under brakeing or acceleration, tires, mileage on tires, elapsed time since last brake job (if symptoms under brakeing)...
Old Jun 27, 2005 | 02:51 PM
shadyr78's Avatar
98 A4, 103k miles, stock suspension, tires are still 90% good w/ 205/55/r16's.
this morning it seemed to have gotten worse, i put the car in drive and it seems to feel bumpy right away. and on the streets and highway this morning the front end shook was vibrating...like i'm running over the reflectors on the road. i checked the tires for any bubbles or tire chunks missing but everything was fine.
Old Jun 27, 2005 | 03:34 PM
Mr_You's Avatar
This is just a wild guess, but maybe the wheel is off balance?
Old Jun 27, 2005 | 05:13 PM
Danase's Avatar
Did it "bump" when you put it in gear? Could be an engine mount.
Old Jun 27, 2005 | 05:23 PM
AWDaholic's Avatar
Cud be wheel bearings, too. But that usually manifests itself as more of a grinding than a bumpiness. Best way to do a field check is to park the car on level ground, wheels pointed straight. Stand adjacent to the wheel and place your foot on the top of the side of the tire (either one, but ONLY one, as using both will cause you to fall on our azz). Push, SHARPLY, with your foot against the tire. If you feel ANY looseness... Any wiggleing... Anything you might misconstrue as metal bumping against metal, it cud be your wheel bearings. Repeat for other side remembering to use ONLY one foot, lest you fall on your azz over there, too.
An absense of these symptoms doesn't absoutely rule out wheel bearings, but if you DO feel them, it probably is.
Also, it might nt be a bad idea to have an experienced (read: non-shadetree) mechanic check out your tie-rod ends. I don't know if/where there might be suspension bushings for your year/model (others with more specific knowledge of your y/m will chime in, I'm sure), but maybe have him visually inspect those, too, if they exist...
That's all I can think of, at the moment. NEbody else...?
Old Jun 27, 2005 | 06:19 PM
shadyr78's Avatar
well, i just droped the car off with my machanic during my lunch break. i'll post up what he says later tonight. hopefully my wallet won't be hurting[&:]
Old Jun 28, 2005 | 11:10 AM
Danase's Avatar
Any word on it yet?
Team Supreme
May 4, 2011 10:32 PM
cantdrive55
Jan 25, 2008 05:55 PM
paaudia6
Nov 26, 2007 07:19 PM
Imejia
Oct 14, 2006 07:41 PM
Audinam
Jun 24, 2006 04:54 PM
