Noise coming from front of engine
Old May 4, 2011 | 08:23 PM
Team Supreme's Avatar
Default Noise coming from front of engine
http://youtu.be/9zpK_-eCxAs
what is it?
Edit, 1998 a4 2.8 v6
Old May 4, 2011 | 08:33 PM
krazzz's Avatar
It's a little hard to tell on the video but it sounds like it could be the cam chain tensioner. Is it towards the front on the drivers side only? I just replaced mine a few weeks ago. Get a mechanics stethoscope ($10) and you will be able to pinpoint it easily.
Old May 4, 2011 | 08:48 PM
How much did that cost?
Old May 4, 2011 | 09:17 PM
krazzz's Avatar
I have a spare parts engine so for me it was FREE I have seen the part for sale for about $250. This is a pretty advanced DIY so you would need to be pretty comfortable tearing into your car.
Old May 4, 2011 | 09:32 PM
well i have a tbelt job coming up, should I just add that to the list for the shop to do?
Old May 4, 2011 | 09:51 PM
ImTheDevil's Avatar
Shine a light down there and see if the serpentine tensioner is wobbling - when the bearings begin to fail, the belt won't run perfectly smoothly over the pulley on the tensioner and you'll see it wobble. I've seen a couple of failures like this - you'll have noise that'll get worse in a fairly short time, and then blow apart and spit out your serpentine belt. A new tensioner is about $40 and adds no labor to the job because the part comes off during a timing job. If it was a cam chain tensioner, it'd be at the back of the head. You could also pull a timing cover and see how the timing belt is running (smoothly or otherwise).
Old May 4, 2011 | 09:54 PM
Damn, if it just happened today how long would you say I have at 10 miles a day to the car. I don't have a 1000+ right now for the TB job. Sad day man, sad day.
Old May 4, 2011 | 10:06 PM
krazzz's Avatar
He has the V6 so the cam tensioner is at the back on the passenger side and at the front on the drivers side. Thats why I asked if he is hearing it more from the drivers front. I think a stethoscope is a must have in any tool kit because it allows you to really pinpoint the source of sounds. Takes a lot of the guess work out of it.
Old May 4, 2011 | 10:12 PM
ImTheDevil's Avatar
^^^ sorry, didn't read it closely enough. That's correct. OP, you can spend a fraction of that on some basic tools, a set of Allen bits, and a set of ritz bits, and DIY the job. This forum can help you - many of us have extensive knowledge of these cars and what isn't apparent from the DIYs (which mainly are for the 1.8T but correspond for removal of the front clip at least), we can help you with. If you're basically mechanically inclined, you CAN do this job.
Old May 4, 2011 | 10:32 PM
Not so much mechanically inclined but I do have common sense. haha
andrew.castaneda
Oct 10, 2014 09:40 AM
Cioffie
Aug 21, 2011 03:34 PM
paaudia6
Nov 26, 2007 07:19 PM
Audi_Skydiver
Mar 7, 2007 04:10 AM
Imejia
Oct 14, 2006 07:41 PM
