Windshield washer pump? 2000 A4 2.8
Old Nov 21, 2007 | 07:16 PM
kwsmithphoto's Avatar
Default Windshield washer pump? 2000 A4 2.8
Hi. New here, glad I found this place.
My fiancee has a 2000 A4. It sure spits out a lot of expensive parts! Part of the reason no doubt is that it only has 58K on it, lots of short thermal cycles in urban conditions. She's always maintained it by the book but that hasn't stopped it from hurling parts all the time. I looked at her receipts and it's on it's 3rd radiator. My favorite is when the thermostat stuck open last winter. $450 labor to replace a $35 part. Dumb.
ANYWAY, the windshield washer pump just stopped working. It was never run without fluid in it, it simply stopped working. It shares a fuse with the wipers which work, so it isn't that. Is this an easy fix I can do without a manual, or should I visit my local (and very busy) independent Audi repair shop?
Thanks!
[align=left] [/align]
Old Nov 21, 2007 | 07:19 PM
auditech79's Avatar
Default RE: Windshield washer pump? 2000 A4 2.8
Pull out the driver's side headlight assembly and look down, you should see both washer pumps there, dis-connect the connector and check for voltage at the pump with someone activating the switch.
Old Nov 21, 2007 | 07:57 PM
Thanks for the quick reply!
Two pumps? This car doesn't have headlight washers so I'm guessing there's just one, yes?
Old Nov 21, 2007 | 07:58 PM
auditech79's Avatar
Yes then you will have just one.
Old Nov 22, 2007 | 02:04 AM
Thanks! I'll give it a look when I get home.
sirluc
Mar 1, 2015 12:43 AM
AudimaniaA4
Jan 4, 2011 08:23 AM
earth havoc
Mar 3, 2009 12:11 PM
a3square
Feb 21, 2007 08:17 AM
elmerbug
Jan 26, 2007 02:48 PM
