windshield wipper fluid light
Old May 30, 2006 | 05:01 PM
98audia41.8t's Avatar
Default windshield wipper fluid light
hey yall this is probably one of the most annoying things to me...
my windshield wipper fluid light keeps coming on and it wont turn off
ive filled it up like 10 times and ive used an entire bottle of fluid on it but it has yet
to shut off......any suggestions??
Old May 30, 2006 | 05:10 PM
acetrebo's Avatar
Default RE: windshield wipper fluid light
Is it leaking?
Is it completely full?
If its not holding fluid, look at the connection in the bumper, common to leak there.
Check the sensor connection and make sure its connected and not corroded.
Old May 30, 2006 | 10:02 PM
ejc317's Avatar
i had that problem before - it was a fuse
Old May 30, 2006 | 10:15 PM
onepoint8tee's Avatar
Most likely one of the 2 pumps leaking (or both) that sit in the resevoir. They have plastic housings that slide into the fluid resevoir, and crack over time and leak. I had the same problem. I cant find the DIY on audiworld that i used.. But you gotta take the drviers side wheel/liner off and take the bolts off holding the resevoir in.. Remove the hoses attatched and remove the container.. Remove the pumps and fix or replace them.. I used appoxy to seal the cracks, then wrapped the pump housings with electrical tape and all is good. Kinda a mcguiver fix, but its been over 6 months and still no leaks. Takes about an hour total. VERY common!
I dont know how a fuse would cause you to lose fluid???
polyflon
Jan 9, 2014 07:15 PM
ggspeed860
Feb 26, 2010 09:31 PM
stathound
B8 Models
Feb 11, 2009 10:24 AM
Audi311
Dec 11, 2008 07:48 PM
kidpositive
Nov 20, 2005 07:01 PM
