wiper problem
Old Dec 14, 2006 | 08:37 AM
Megathunderultrazord's Avatar
Default wiper problem
recently the wipers on my Audi A4 have stopped working but the screen washers do work, i think it is a relay problem if so where is the wiper relay located.
Old Dec 14, 2006 | 10:03 AM
techbod's Avatar
Default RE: wiper problem
ok its an Audi A4, what year/ engine size obvious need to know stuff
Old Dec 31, 2006 | 11:27 AM
1996, 1.8 (1781 CC) if it helps its also an automatic
Old Dec 31, 2006 | 11:48 AM
techbod's Avatar
the wipers don't have a relay as such just a relay for intermittent wash wipe, #24 fuse if for the wipers and windshield washers so if they are working it could only be a couple of things
1. bar came off from the motor you would need to inspect that area ( can you hear the wiper motor at all?? this would indicate that's the problem
2. burned out motor
3. wiring problem
Old Dec 31, 2006 | 11:55 AM
techbod's Avatar
nearly forgot
4. wiper stalk on the steering wheel not making contact try spraying into there with some dielectric spray to clean the contacts and I missed ) that one out of the other post
Old Dec 31, 2006 | 01:58 PM
in the morning when i start the car and i put my wipers on they work for a short period and then just cut off.
Old Dec 31, 2006 | 02:01 PM
techbod's Avatar
that sounds like the stalk switch loosing contact like when you flick the switch for a single wipe
gordond
May 9, 2008 03:10 PM
aberfitch82
Jan 23, 2008 09:16 AM
gzenanko
Dec 29, 2007 03:44 AM
1998ta__1991rs
Sep 19, 2007 10:05 PM
Dec 9, 2006 01:28 PM
