Is this worth it?
Old Jul 17, 2006 | 11:44 PM
05fordgt's Avatar
Default Is this worth it?
I am trying to decide whether I should buy this Audi A4 I found? the guy wants 4900 for it here is what it has. My question to you all is this. For 4900 is this a good deal, could i make more on it or is this just a average price?
1996 Audi A4 AWD Quattro
2.8 liter V6 with variable intake manifold, digital electronic management
Abs system
Electronic differential
16x7 premium audi 5 spoke wheels
Rack and pinion variable assist power steering
Four link front suspension, stabilizer bars
Factory alarm
Electronic climate control w/ pollen filter
Power windows w/ one touch down and up feature
8-way power drivers seat
Titanium leather upholstery
Factory All Weather package
5 speed Manual transmission
Power locks, windows, mirrors, sunroof,
Heated Seats and Mirrors
Walnut Wood inlays for dash, console, and doors
Loaded
S4 Sport steering wheel
Clean title, clean car fax
127,XXX miles
Have all records, paperwork, original car sticker, owners manual,ect.
Newer parts with records
T-stat
Water Pump
Timing belt
Idler pulley
Tensioners
Pulley tensioners
Power Steering pump
Coil packs
Plug wires
Outer Cv boots
Engine galley cover gasket
Intake Manifold gasket
Throttle body gasket
Egr gasket
Egr valve
Front abs sensors
Rear wheel bearings
Front pads and rotors
Rear pads and rotors
Power steering pump
Other newer parts but no paperwork
Tires
Lightweight flywheel
Clutch and pressure plate
Testpipes (midpipes)
Kenwood Excelon cd/mp3 deck X889 (top of the line)
Jbl amp for subwoofers (no subs in car)
Cold air intake
Premium tint all windows
Halo 1pc smoked headlights
VIS carbon fiber hood
Reiger RS4 Front bumper
2 stage Pearl blue paint job
Issues with the car
Has a dent on the rear passenger side door
sunroof is unhooked (not sure if it works)
drivers seat is loose
paint is dull needs to be compounded (wheeled and waxed)check engine light is on was told its a emission code (aka o2 sensor car has midpipes)car looks like it has took a hit on the front passenger side at one time has been repaired perfectly i had it checked on car fax no accident shown, air bag light is on stays on for 4 minutes then turns off, previous owner said its a sensor under the drivers seat that was replaced but havant had the light reset. Also has a very small exhaust leak right where the test pipe and oem ehaust is welded on.
Thanks,
05fordgt
Old Jul 17, 2006 | 11:51 PM
BFlan2001's Avatar
Default RE: Is this worth it?
where do you live?
it's not a bad deal but nothing special
05fordgt's Avatar
Michigan
Old Jul 18, 2006 | 04:05 AM
BaconBait's Avatar
Nothing too bad. Take it to a euro shop and have them take a look at it. Get an estimate for the airbag light and check engine light. I'm not sure hor the vehicle inspectionis where you are, but in most states if your check engine light is on, you will automatically fail.
Old Jul 18, 2006 | 11:01 AM
joe4123's Avatar
Member
Thats not too bad at all, just get those lights checked out to make sure theres not a hidden prob.
Old Jul 18, 2006 | 07:42 PM
acetrebo's Avatar
Sounds like a fair price for the condition.
At least the 120k has been done, and no other major problems. Looks like they replaced a lot of stuff.
Have it looked over first, then go for it.
Of course, if you are wanting to mod, hold out for a 1.8T, but otherwise this seems like a fair deal.
Old Jul 18, 2006 | 08:03 PM
Dj Spiel's Avatar
sounds cheap.
Old Jul 18, 2006 | 08:11 PM
Dj Spiel's Avatar
take for t-drive & take to mechanic
Old Jul 18, 2006 | 10:28 PM
robfresh's Avatar
It sounds like a good deal but still look further into it about the lights.
FASTER
Jan 8, 2011 09:19 PM
MarkR540
Oct 31, 2010 09:17 PM
moeron7
Apr 16, 2008 12:59 AM
Carlos10704
Apr 1, 2008 05:05 PM
bryans 86
Feb 18, 2008 10:54 AM
