woundering how to tune my 98 audi a4
Old Oct 17, 2007 | 12:47 PM
ragingmastiff's Avatar
Default woundering how to tune my 98 audi a4
MANIFOLD - STAINLESS 1.8L T3/T4 also got440cc / 44lb fuel injectors / bosch green tops and i got a test pipe
so maybe some software i know gaic wont work with this turbo and a fuelmanagment system
T3/T4 FLANGE .70 HOT SUPER SPOOL
38mm WG BRAND NEW
RFL BLOW OFF VALVE - BRAND NEW
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
TURBO ACCESSORIES !!
INTERCOOLER
MANIFOLD INFO:
This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars.
Manifold has flange for an external wastegate. And since this manifold is tubular steel, it flows better than cheap cast iron
and is less prone to cracking. It was custom-made to be used with A 2 BOLT external wastegate.
TURBO INFO:
T3 TURBO INFO AUDI T4OE TURBO
3" INLET DIAMETER
3 V-BAND" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
.50 A/R .70 HOT
57 TRIM
SPECS:
STAGE IV WHEEL
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
[align=center][/align][align=center][/align][align=center][/align]
Old Oct 17, 2007 | 01:12 PM
AudiCross's Avatar
Default RE: woundering how to tune my 98 audi a4
wow...intense. do you want to go standalone tuning or predone?
Old Oct 17, 2007 | 01:34 PM
chaos92287's Avatar
tell me thats not an ebay kit
Old Oct 17, 2007 | 01:53 PM
akielb's Avatar
You put four jack stands under then car so all four wheels can spin - then you have a friend stick his head under the hood while you rev the engine. The trick is to keep yelling - HOWS THAT?
Old Oct 17, 2007 | 02:21 PM
qUaTtRoA4's Avatar
ORIGINAL: chaos92287
def looks like an eBay kit....
take a look at unitronics....
gl!
Old Oct 17, 2007 | 02:25 PM
chaos92287's Avatar
^yeah thats what i thought. but yeah unitronics, mika, revo. they all make BT tuning. i wonder if thats one of the super glued models? already know its gona have quite the bit of lag since its a floating bearing. shoulda just bought a gtrs elim
Dj Spiel
May 18, 2010 01:15 PM
marlonduval
Jan 13, 2008 12:34 PM
marlonduval
Dec 19, 2007 12:09 PM
ragingmastiff
Oct 18, 2007 02:00 AM
FIUPike83
May 30, 2007 02:08 PM
