WTF!!!!!
ORIGINAL: BaconBait
Put one part of the pliers on the tab at point B and put the other half on the opposite edge of A. Then squeeze. Be careful to not pinch your hand if the pliers slip. Cause it sucks.
Another thing you can do is grip the pinched bulging point and pull on it intil is straightens out a bit, then pull the hose off.
hmmm... i dont know if it just a stock replacement or not. it's black liek the stock one.
the diff netween the two is performance basically, the valve controls when your turbo spools and what not by regulating the pressure. the 75h will make the turbo spool sooner and smoother and you might gain a psi or 2
