WTF INTAKE
Old Jan 7, 2007 | 03:34 PM
raffysaudi's Avatar
Member
Default WTF INTAKE
Yesterday i took off my Hks intake to clean it and where the o2 sensor is there is a thin piece of plastic insite the intake pipeing and a little part of it chipped of and when ever my o2 sensor is connected when i start the car the Check Engine Light is on and when starting the car revs up to .5 Rmp anout 3 times then 1.5 Rpms and returns to normal when i disconnect the sensor it starts fine but the light is still on what could this be anyone know1.5
Old Jan 7, 2007 | 03:48 PM
onepoint8tee's Avatar
Default RE: WTF INTAKE
ORIGINAL: raffysaudi
By 02 sensor, you mean MAF sensor. I dont know how anything broke off, but your maf is dead. The best way to determine a bad MAF sensor is to unplug it and see if it runs ok, if it does, the maf is dead (if you have running issues with it plugged in). You dont want to run the engine for long with the maf disconnected because youll run really rich. Get whatever chips of anything that are in the ducting out asap because your turbo will take a crap if it sucks anything in like that.
Your 02 sensors are screwed into the catalytic converter btw.
and MAF sensor = mass airflow sensor or some call it an airflow meter.
Old Jan 7, 2007 | 04:44 PM
raffysaudi's Avatar
Member
Tahts what i ment sorry when it is pluged in it runs good but not at the beggining when its unpluged it runs and starts fine
Old Jan 7, 2007 | 04:55 PM
BadLuckAudi's Avatar
yea sounds like a bad maf or some crazy boost leaks but my moneys on maf
Old Jan 7, 2007 | 05:13 PM
tooxtreme8813's Avatar
he is 99.5 so he doesnt have a map sensor, if he unplugs his maf the car will run worse
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
