WTF! Look at my dipstick!
ORIGINAL: ThePaintballGuy
Is that only if there is a complete loss of vacuum or just a little bit? I am running at about 12hg when idle and last time I changed my plugs they were wet. I am going to go get a bunch of vacuum hose and replace it all when I tear my car apart next weekend.
And would that also make my MPG go way down???? (I am not trying to jake this thread. Just wondering because I know Alias is having vacuum problems to right?)
Josh
Josh
Ok, so if I replace all the lines then it should fix it correct? How much tubing should I get???
Josh
Josh
hmm, well pcv is forPositive Crankcase Ventilation
you might want to see if yours is plugged, you can probably find alot of info on this
on like the internet, more then what i care to write, but its just a posibility
anyhow, it returnsgases to your combustion chambers
but
but
Ok well I was able to take a couple of my spark plugs out today. Neither of them were dripping wet, in fact, they were both like bone dry.... Does that mean I am not running rich?
I will be replacing the CTS in a little while here, I want to let me engine cool for a little bit.
ORIGINAL: alias747
Alias:
when you last did your oil, did you put in the same oil filter the car came with (the big one) or did you put in one form like K&N that is smaller. if you did, that would defanitly cause you to have a high oil level
when i did the oil first time on my car, i did that and it read high somethin like urs. go back to the bigger filter, these engines need all that extra oil for cooling becuase of the turbo and such
