WTF! Look at my dipstick!
Old Apr 2, 2007 | 10:51 PM
  #21
2k S4's Avatar
Default RE: WTF! Look at my dipstick!
ORIGINAL: ThePaintballGuy
Is that only if there is a complete loss of vacuum or just a little bit? I am running at about 12hg when idle and last time I changed my plugs they were wet. I am going to go get a bunch of vacuum hose and replace it all when I tear my car apart next weekend.
And would that also make my MPG go way down???? (I am not trying to jake this thread. Just wondering because I know Alias is having vacuum problems to right?)
Josh
Any change in vacuum will change the FPR. I think 12hg is high for idle it should be 16-20hg. The plugs SHOULD NEVER be wet. Yes, you are running super rich. Yes you will get horrible MPG. The vacuum will not be the same @ every place in the engine.
Old Apr 2, 2007 | 10:53 PM
  #22
Audi_Skydiver's Avatar
Ok, so if I replace all the lines then it should fix it correct? How much tubing should I get???
Josh
Old Apr 2, 2007 | 11:02 PM
  #23
2k S4's Avatar
Josh
Only if you have a vacuum leak in the hose. The tubing is cheap, get 3m of it.
Old Apr 3, 2007 | 05:08 AM
  #24
zrwhat's Avatar
hmm, well pcv is forPositive Crankcase Ventilation
you might want to see if yours is plugged, you can probably find alot of info on this
on like the internet, more then what i care to write, but its just a posibility
anyhow, it returnsgases to your combustion chambers
but
Old Apr 3, 2007 | 08:38 PM
  #25
alias747's Avatar
Ok well I was able to take a couple of my spark plugs out today. Neither of them were dripping wet, in fact, they were both like bone dry.... Does that mean I am not running rich?
I will be replacing the CTS in a little while here, I want to let me engine cool for a little bit.
Old Apr 3, 2007 | 08:51 PM
  #26
2k S4's Avatar
ORIGINAL: alias747
If they were wet, then that's super rich & almost flooded. What color where they? If you want to find out how rich you are running, just Vag-log your O2, it will tell you what your running for a AFR.
Old Apr 3, 2007 | 09:03 PM
  #27
alias747's Avatar
The side electrode was like white and almost like chalky.
Old Apr 4, 2007 | 01:11 AM
  #28
alias747's Avatar
Is white and chalky bad?
Old Apr 4, 2007 | 01:12 AM
  #29
It has to be better then mine when I pulled mine out. They were black and dripping!!
Josh
Old Apr 4, 2007 | 04:12 AM
  #30
AudiCross's Avatar
Alias:
when you last did your oil, did you put in the same oil filter the car came with (the big one) or did you put in one form like K&N that is smaller. if you did, that would defanitly cause you to have a high oil level
when i did the oil first time on my car, i did that and it read high somethin like urs. go back to the bigger filter, these engines need all that extra oil for cooling becuase of the turbo and such
