You guys like my custom intake?? :)
Old Feb 11, 2007 | 04:43 PM
McGuireDennis's Avatar
Default You guys like my custom intake?? :)
Have been talking about it for a while now, finally here are some pics.
Old Feb 11, 2007 | 04:57 PM
sean1.8t's Avatar
Default RE: You guys like my custom intake?? :)
sorry to say but your stock box was better.. but you can fix it with a better heatshield
Old Feb 11, 2007 | 05:03 PM
techbod's Avatar
bog standard cone filter from your picture
Old Feb 11, 2007 | 05:30 PM
onepoint8tee's Avatar
ya make sure you fabricate a GOOD heat shield. Im sure it sounds good though.. And why did you keep the horn/trumpet on there??? (after the maf-between maf and filter) Its really only useful when in the stock airbox, and i dont see how that filter can be sealed up against it very well since there is a lip on the end of it...?
Sorry to keep knit picking, but i would also turn/twist/aim your MAF so the wiring is facing the opposite way, not towards/leaning onthe hot side/heat shield.
Old Feb 11, 2007 | 08:14 PM
ORIGINAL: avant80@2.6
I don't know what this means, pardon my ignorance..
Old Feb 11, 2007 | 08:17 PM
ORIGINAL: onepoint8tee
Dude any criticism is good criticism, so dont hold back.. Well I kept that piece because if I took that out, I wouldn't be able fasten the cone anywhere, and it is sealed pretty good it is fitted right on the lip and does't move..
Old Apr 29, 2007 | 03:29 PM
a41.8Tblk's Avatar
dennis where did you get that adapter for the sensor?
Old Apr 29, 2007 | 10:17 PM
Those pieces are already inside the intake box I just used those..
If you look in the intake you'll see them
ORIGINAL: a41.8Tblk
Old Apr 29, 2007 | 10:41 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: McGuireDennis
He is from the UK, you'll only get about 1/2 of what he says, still learning the naming differneces.
Your intake is fine, just clean things up a bit and your good.
v3n0m
Sep 23, 2010 01:00 AM
JG99AudiA4
Apr 21, 2009 05:02 PM
AWDrifter
Apr 5, 2009 05:56 PM
wyldstallian
Sep 11, 2005 05:04 PM
audihere
Feb 15, 2005 01:03 AM
