01 A6 Parktronic Help
Old Aug 13, 2007 | 01:03 PM
RedShoeRider's Avatar
Default 01 A6 Parktronic Help
Good Day, All:
I've got a fun one. Well, ok, it's not that fun.
The car: 01 A6 2.7T.
The gotcha: The Parktronic doesn't work. It makes the nice "Beeeeeep" when I put it in reverse, but I get nothing on the display. Hooked up the Vag-Com (gawd, that thing is great), and it informs me that the drivers side sensor is faulted. I checked the wiring and couldn't find a thing wrong, so I assume the sensor has gone south.
So, where can I find a replacement sensor (I know I can to the Stealership, but I'd prefer not to), and how on earth do I go about changing it?
Thanks!
-Red
Old Aug 13, 2007 | 01:48 PM
Blade69's Avatar
Default RE: 01 A6 Parktronic Help
It has "Parktronic"? Is that something that can be turned on and off? I've never gotten a beep and I did "nudge" a car behind me yesterday.
Old Aug 13, 2007 | 02:02 PM
The Parktronic (or should we properly say: Acoustic Parking Assist System) system was an option on the 01' A6. I believe you got it if you purchased the Nav package (the expensive little bastard that was). It's easy to tell if you have the system: look at the rear bumper. If there are 4 circles about 1" in diameter running down the horizontal midline of the bumper, you have it. Those are the acoustic transcievers. No circles = no parktronic.
Old Aug 13, 2007 | 02:04 PM
techbod's Avatar
I assume you would have to remove the bumper
1- Oval head self-tapping screw - 1 Nm 2- Wheel housing liner 3- Guide q Removing 4- Hexagon collared nut - 6 Nm 5- Hexagon collared nut - 6 Nm 6- Combi bolt - 23 Nm 7- Impact absorber
8- Cross member
9- Clip q For trim panel 10- Cover q Removing: – Partially remove luggage compartment trim. – Disengage cover sideways from guide and detach. – Unplug connectors if applicable.
11- Trim panel
[IMG]local://upfiles/12092/9D85AD8CA16C4614A5521151415CE1B5.jpg[/IMG]
dwells
Apr 1, 2014 09:41 PM
Heckler
Feb 16, 2010 08:56 AM
madman1234509
Apr 25, 2009 09:40 AM
RedShoeRider
Mar 1, 2007 10:36 PM
996GT3RSRRacer
Feb 7, 2007 11:29 PM
