06' A6 Checklist.
Old Dec 18, 2008 | 03:31 PM
VetalAudi's Avatar
Thumbs up 06' A6 Checklist.
Hello everyone!
Hopefully, I am going to get an 06' A6 some time soon. I'd really appreciate if you could give the list of what should I look into when getting this car, what should be changed and checked in the nearest future. I've searched the forum and I managed to find such list, but for an older model.
Thanks a lot.
Old Dec 18, 2008 | 07:12 PM
Kevin's Avatar
Get the maintenance records and make sure that the MMI software has been updated. Subscribe to Bentley's and get copies of all the outsatnding TSBs for the car. Then make sure to have all of the TSB work performed while the car is still under warranty. Welcome to the club.
Old Dec 18, 2008 | 07:40 PM
VetalAudi's Avatar
Great, thank you.
How about the parts, pumps, suspension, wiring ? As far as I know A6 of this model has a timing chain instead of a belt, any concerns with that ?
Cheers.
Old Dec 19, 2008 | 07:03 AM
Kevin's Avatar
If you want details I will give you details. I have an 05 4.2 that I purchased new nearly 4 years ago. She currently has 53k on the odometer. As far as reliability, she is ok, but she is no Lexus. But she is alot of fun to drive. Most of the problems have been nuisances.
The airbag light came on two weeks after I purchased the car. It took them 10 days to figure out the problem. Audi then came out with a TSB on updating the computer software for the airbags.
The MMI "crashed" a year after I bought the car. After having the car for 8 days, Audi wiped the hardware clean and reinstalled the MMI computer software.
The MMI had a few bugs with not updating the satellite radio stations, losing surround settings and sometimes not automatically linking with my bluetooth phone. Audi had the car for a day and updated the MMI computer software. Audi has a TSB on this issue as well.
I have written those three problems off to having a very early computer software version. To give you an idea of the number of changes in the software, my car came with MMI version 10 and now has version 33. Since being updated to MMI version 33, about a year ago, I have not had any computer issues. I understand that there is now a version 41 that is available. Since my MMI has been stable with version 33 I have not upgraded to 41. From fellow Audi owners I understand that the differences between 33 and 41 are negligible.
As far as non-computer issues. I have had quite a few. The first was that all 8 coil packs had to be replaced. The second was the lid for the gas cap would not open from inside the car. In order to open it I had to wedge my credit card inside the lid and open it from the outside. Audi had the car for 2 days to fix these problems. The third was that the frame for the front passenger seat came loose and the entire seat had to be removed and the bolts tightened. The fourth was a rattle in the glove box area of the dashboard. The fifth was a bad tire pressure sensor. The sixth was a mildew smell from the air conditioner vents, which required the replacement of a ventilation duct. The seventh was a rattle from the rear fold down seats, which required a new clamp. The eighth is a rattle from the drivers side of the dashboard, which required additional damping material. The ninth is the fuel filter recall, which required a new fuel filter. The tenth is the fuel gauge sometimes reads empty even though there is fuel in the tank, which required a computer software upgrade. The eleventh is that the transmission developed a chirping and the transmission software had to be upgraded. The twelfth is that the coolant light would come on for no reason, which required an upgraded electrical circuit. The thirteenth is that the power steering reservoir leaked, which required a revised clamp. Fourteenth, the front brakes developed a vibration at slow speeds and the brake caliper seals had to be replaced due to a re-design. The fifteenth is that the the motor for the power tilt/telescoping steering wheel had to be replaced because of a groaning noise. The sixteenth is the motor for the rear power sunshade had to be replaced because that motor was groaning and clicking as well. The seventeenth is that the coolant temperature gauge stopped working. Similar to the computer issues discussed above, Audi has TSBs on all of these issues, seeming to indicate that the problems are not isolated to just my car. Audi has also issued dozens of other TSBs on issues that I have not experienced since I have the 4.2 engine instead of the 3.2 engine. In total, the 3.2 has over 200 TSBs, which is Audi's lingo for an unpublished recall. If you complain about these items while the car is under warranty, Audi will fix the problem for free, which sounds like a recall to me.
Despite the car being at the dealer for over 40 days for repairs during the last 45 months, not maintenance, I would certainly buy the car again because the 4.2 is alot of fun to drive, especially on the highway,and the dealer gives me a loaner. However, I would check which MMI software version is currently in the car. If it is below 33, I would take it to Audi and have it updated as soon as possible. In addition, I would check the car's VIN and compare it to the Audi TSBs and see what issues you need to keep an eye on. You can get copies of the Audi TSBs at eBahn's website. The dealer will probably give you the car's maintenance records. While the car is still under warranty, I would make sure you complain about any issues contained on the TSBs issued for your VIN. If you are buying an aftermarket warranty I would get an exclusionary warranty that your local Audi dealer accepts.
Despite the issues with the car, I think that it is a great driving car. However, keep in mind that I am an original owner who paid close to $60,000 for my daily driver and who according to my wife is the President of the "More Money than Brains" club. For example, changing the transmission fluid costs over a $1,000 just for the fluid, not including labor. Also keep in mind that the 55,000 mile service is the "major" service for the car. If money is an issue, you may want to look for a car that is cheaper to "maintain". Regardless of your decision, you will enjoy driving an Audi, but you may not enjoy the maintenance. Good luck.
Kevin
Old Dec 19, 2008 | 11:42 AM
nemohm's Avatar
An excellent post!
Your remark in regard of the "changing the transmission fluid costs over a $1,000 just for the fluid" ?
Based on the current pricing you must have a transmission that gets more than 50 l of fluid?
Correct?
gsdrk-1
Audi Q5
13
Dec 6, 2014 08:33 PM
A4TurboGuy
Apr 24, 2014 07:35 AM
Juan Santos
Feb 26, 2014 07:21 PM
nvr_follow_a4
May 29, 2008 09:06 AM
drkenan
Feb 2, 2006 09:25 AM
