P0411 Checklist
Old Apr 19, 2014 | 11:25 AM
A4TurboGuy's Avatar
Default P0411 Checklist
Does anyone have a checklist of the components involved from cheapest to most expensive?
My boost gauge is reading -40 when measuring vacuum, so I seriously doubt it's a vacuum leak.....but I did just install all (4) new check valves. Does anyone have a reliable diagram as to which direction they should be facing (inline)?
Thanks
Old Apr 20, 2014 | 06:20 PM
Pbcrazy's Avatar
Did this happen as soon as you installed the check valves? The check valves have an arrow that point towards the motor
Old Apr 21, 2014 | 11:23 AM
A4TurboGuy's Avatar
It's possible, but I'm almost certain I replaced them the way they came out.
I'll check again - I was thinking that might be possible, but I wanted to hear some personal achievements that over-came this obstacle.
Old Apr 21, 2014 | 03:10 PM
Pbcrazy's Avatar
I've never had this problem as I don't have a secondary air pump in my AEB. -40 vacuum is quite drastic I wouldn't even drive it at that
Old Apr 22, 2014 | 08:48 AM
A4TurboGuy's Avatar
Well. the (analog) gauge (which is tapped into the FPR line) bottoms out at -30, but it drops lower than that, so it may only be -30, but could be -40.
Why do say that though? What's wrong with having that much vacuum? I can't see it doing anything other than pulling more air into the intake, but I've been wrong before, so what's on your mind?
Old Apr 23, 2014 | 08:20 PM
Pbcrazy's Avatar
I'm just guessing but having that much vacuum could start to collapse brittle lines possibly, I have no proof of this being true but have 2x the normal amount of vacuum can't be good. Atleast you know you don't have a vacuum leak haha
Old Apr 24, 2014 | 07:35 AM
A4TurboGuy's Avatar
Well, I've replaced most of the vacuum lines. The only one I haven't replaced is the one towards the front of the engine that look like there's no way to find where it ends or begins.
Any idea what/where that one is?
gsdrk-1
Audi Q5
13
Dec 6, 2014 08:33 PM
Juan Santos
Feb 26, 2014 07:21 PM
VetalAudi
Dec 19, 2008 11:42 AM
nvr_follow_a4
May 29, 2008 09:06 AM
drkenan
Feb 2, 2006 09:25 AM
