1995 A6 Reverse
Old Jun 21, 2010 | 09:38 AM
MAAM's Avatar
Default 1995 A6 Reverse
Lights not working-HELP!
New light bulbs are in and still no joy!
Is it true ....its tied to tranny system?
All advice welcomed!!!
Old Jun 26, 2010 | 09:06 PM
Jeka's Avatar
Have you checked the switch?
Old Jun 27, 2010 | 09:50 AM
MAAM's Avatar
Hi JEKA......
I'm not sure where back-up switch is located....
Your help is appreciated....
Thanks.
Old Jun 27, 2010 | 10:07 AM
jhuffman's Avatar
the switch is usually up under the brake pedal. Pull the driver side lower dash and get a flashlight up in there, should be pretty obvious when you see it.
Old Jun 27, 2010 | 10:16 PM
chefro's Avatar
I thought the C4 (hence his 1995) has a Multifunction Switch that is attached to the transmission and it incorporates the backup lights' function. I need to do some digging since I forgot this stuff from months back...
Old Jun 30, 2010 | 01:09 AM
Jeka's Avatar
Check the tranny. It should be attached to it. If not, go inside the car and open the palstic which covers the shifter.
capecodallroad
May 29, 2011 03:23 PM
Byron88
May 7, 2010 09:39 AM
gee_off2121
Nov 25, 2009 10:31 AM
racso237
Jan 17, 2009 09:13 PM
aramkim
Apr 27, 2008 02:48 AM
