1997 A6 Wagon with Codes, help please
Old Oct 20, 2008 | 08:19 PM
progolfer_20's Avatar
Default 1997 A6 Wagon with Codes, help please
have a 97 A6 wagon with around 110K. Check engine light came on, did a vag com and came up with:
Controller: 8DO 906 266 B
Component: 2.8L V6/2v mpi 0bd2 d02
coding:10242
shop number: WSC 02324
16558 Fuel Trim: System too lean:bank2
P0174-93-00 Unknown Error Elaboration
Readiness: N/a
Any ideas? My wife said the light came on close to starting the car after sitting all day at work. THANKS!
Old Oct 21, 2008 | 12:55 PM
NH_USA's Avatar
Clear the codes and see if it comes back on.
Here is what wicki-ross says
16558/P0174 - System Too Lean, Bank 2
Possible Symptoms
Irregular behaviour
Possible Causes
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
Old Oct 21, 2008 | 11:00 PM
a6hcw's Avatar
A plugged fuel filter could also cause the engine to run lean. Which version of VAG-COM are you using? Why is "Readiness: N/a" ? You could have no codes, but not have the "monitors" ready.
Jason Jackson
Nov 26, 2013 04:17 PM
Horvath
Apr 2, 2012 11:42 AM
AudiInVa
Dec 2, 2011 04:51 PM
SuperA6
Feb 15, 2009 09:02 AM
SweetWagon97
Aug 17, 2006 07:31 PM
