1998 A6 2.8 Quattro AWD vibrates when shift gears
Old May 5, 2010 | 05:38 PM
Ajayy's Avatar
Default 1998 A6 2.8 Quattro AWD vibrates when shift gears
I have a 1998 A6 2.8 2wd auto/tip. I'm getting a horrid shake as I drive the car. It only seems to happen at certain RPM's and at different speeds. I've isolated it to the point the car shifts gears. If I place the car in tiptronic, and shift aggressively the shake is almost not present. If I leave it in auto and driver regularly it shakes at what seems to be the point it shifts gears.
I have just bought it recently so don't know much about it. Can somebody tell whats wrong with it?
Old May 5, 2010 | 07:02 PM
nm3210's Avatar
Does it shake at all shift points, even say 4→5?
Old May 5, 2010 | 11:34 PM
ninetynineA6Q's Avatar
I'd check your front axles. I had a lot of vibration and a good portion of it went away when I replaced the front axles. After that, I still had some vibration when I was on the brakes, but that went away when I replaced all of the front controls arms, TRE's, and SB end links.
My theory is that if the axles are sloppy, when you're accelerating, the load on them reduces the vibration. However, when the car shifts, it unloads the axles and they can move around again until the next gear engages and the slop is taken up. I'm almost sure that the axles I replaced were the original ones, and they had over 200K miles on them, so they were pretty bad.
Old May 6, 2010 | 02:31 PM
Ajayy's Avatar
Yes it does only when it shift gears(Automatic) 3->4 or 4->5 or 5->4 or 4->3.
If i go from 0 to 60 on a stretch it runs fine, but when you slow down from 60 to 40 and the from 40 and up. 50+ is fine since it is in top gear. Only when it has to shift gears it shakes.
Old May 16, 2010 | 04:17 PM
Artur's Avatar
Default i also have similar prob...
mine makes pretty bad noise only when i gear it from parking to D or R or vice versa, and i checked it already and are the the Upper Links that need to be replaced, (you might check lowers too) so you might check that out. hope that could help some...
Old May 16, 2010 | 08:49 PM
nemohm's Avatar
2WD=> CVT?
If this is the case - embrace yourself!
BTW - what is the mileage?
Any change if you rotate the tires?
Do you feel the shake in the steering wheel or everywhere?
Is the shake
-longitudinal
-across
-mixed
Old May 16, 2010 | 09:55 PM
cadman2286's Avatar
Ive got some of the exact problems your mentioning. But when i put it in tiptronic and keep the RPMs higher than 1800, it has no vibrating at all. Are Audi transmissions just not that good?
Melcheck
May 24, 2010 12:03 PM
ericp1.8T
Mar 26, 2010 07:59 AM
tyler1jack2
Feb 16, 2010 09:52 PM
DSMKiller
Sep 28, 2008 10:59 AM
