1998 A6 Antenna base
The antenna base, the rubber part, is breaking apart and I called the dealer didn't know the part number. Is there any way to obtain the rubber base? i have the antenna mast. Does anyone know how difficult it is to change this part? Thanks
Yes, I also had the same problem and I looked everywhere throughout the internet. I finally found a solution. I pulled out one of these rubber bases and noticed an item number written at the bottom of it. Google this item number "8D5035539." This will give you the solution, it is only worth around $10. Easy fix, much easier than I thought!! Spread the word!!
tom schmitt
Aug 19, 2010 08:02 PM
