1998 Audi A-6 steering noise
Old Feb 21, 2011 | 09:30 PM
AudiDriverA-6's Avatar
Angry 1998 Audi A-6 steering noise
Fellow audiphiles,
I am in need of some advice. I own a 1998 A-6 (C-5) and when I turn the steering to the right it makes a "chirping" noise/sound while turning. That happens intermittently and only while turning the steering to the right. It never happens while turning left. I had the power steering pump check and I was told it was just fine. Also no front end suspension problems either. No power steering oil leaks or low power steering oil reservoir levels. Also the power steering belt is brand new and appropriately tighten. I am frustrated because I do not know what to do next. Does anyone have any advice?? Has anyone else experienced a similar situation and what did they do about it?? Any other ideas as of what it could possibly be causing the noise?? I appreciate any and all responses. Thank you in advance.
Old Feb 22, 2011 | 08:48 AM
Jackmup's Avatar
Just some things that come to mind that I would have a look at.
1st have some one turn the wheel and stick your head in there. locate the area of the problem!!!
Can you feel the chirps in the steering wheel?
rack going bad
power steering lines loose
power steering crush washers bad
power steering fluid too cold and not G4000, Is it foamy? Is it low?
Control arm bushings bad
Old Feb 22, 2011 | 11:02 PM
Lets see now:
The chirp is definitely not coming from the steering ; it appears to be coming somewhere from the passenger side dash section.
Rack going bad? Shouldn't I feel/see other symptoms other then the chirping if indeed that were the case? The steering otherwise works well.
Power steering lines loose? Should I have seen some oil leak of sorts. Or lower levels of fluid in the power steering reservoir? Level is exactly where it should be.
Power steering crush washers bad? Possibly. Should there be power steering fluid escaping from the area?
Power steering fluid is not foamy. I do not know if it is G 4000 exactly although it is new. The noise still occurs even after I drive the car for a while. Ofcourse how warm does a car get in the middle of the bitter winter that Michigan is in the mist of right now?
Control arms bushings (control arms in general) were changed and are brand new on both sides since last October (2010).
I truly appreciate you taking the time and answering my thread; I thank you very much for that.
holness123
Jul 6, 2014 04:34 PM
MattTack
Apr 21, 2013 05:10 PM
cberitzhoff
Aug 7, 2009 03:41 AM
piledriver
Feb 20, 2009 05:45 PM
Rarh
Dec 12, 2005 10:57 PM
