1998 Audi A6..imput needed
Old Feb 25, 2009 | 10:38 AM
dp1967's Avatar
Default 1998 Audi A6..imput needed
I test drove a 1998 A6, 135,000 miles. It sat for almost two years...tied up in an estate battle. The transmission shifts really hard in all gears. Asking price is 2,500. What is everyone’s opinion.....something to look into or run far and fast?
Old Feb 25, 2009 | 12:07 PM
Jeffla's Avatar
I would say that a 98 A6 with 135k is a 6k dollar car, well here in MN at least. If you can have a transmission shop check it out before buying I would. If not, I would pass as you will probably need to do a timing belt just in case, and with a potential transmission failure... There is the potential to be out a lot of money. Have the control arms been replaced, shocks, motor mounts, cam seals.....?
Just a though.
Jeff
Old Feb 25, 2009 | 12:17 PM
zippy_gg's Avatar
At a minimum I would replace all the fluids, including the ATF - that may resolve the hard shifting, assuming you are talking about a Tiptronic.
Check the tires for roundness since the car has been sitting for 2 years. They may need to be replaced so you need to factor this in.
In the end you may have a great car for not too much money, depending on your mechanincal abilities (I am thinking timing belt as mentioned by Jeff).
thenickbutler
Sep 18, 2014 12:01 PM
BattleToad
Nov 10, 2009 07:41 PM
stjacket
Apr 24, 2009 06:03 PM
wkayl
Nov 18, 2008 09:21 AM
a4autocrossr
Jan 29, 2005 05:19 AM
