1998 audi a6 wagon quattro 2.8 custom plans
Old May 14, 2015 | 10:08 PM
providencepistons's Avatar
Default 1998 audi a6 wagon quattro 2.8 custom plans
i need ideas suggestions and parts for 1998 audi a6 wagon quattro 2.8 custom job
any ideas i have to fix the front
Attached Thumbnails 1998 audi a6 wagon quattro 2.8 custom plans-dscn3009.jpg   1998 audi a6 wagon quattro 2.8 custom plans-dscn3008.jpg
Old May 14, 2015 | 10:36 PM
Nebuchadnezzar's Avatar
What do you mean by custom?
From the looks of it, you're going to need AT LEAST:
Hood
Bumper cover
Grill (Upper and lower)
Hood strut
Hood latch
Radiator
Condenser (Probably the high level cut off switch, too)
Radiator support (Sometimes referred to as a 'lock carrier')
Headlight (Most likely both)
Timing cover(s) (depending on how far back everything was pushed)
Other pulleys and belts that were most likely damaged
Check for vacuum leaks from hoses being damaged from the engine shifting around
Check the engine mounts to see if they were damaged in the collision
Also be prepared to switch out weird things like kombi valves and stuff towards the rear of the engine that you didn't think would be touched by a front end hit like that. I just worked on a 2003 A4 with a very similar front to what is pictured and I had to replace a few odd ball things because the engine was thrown back a little during the impact.
Old May 18, 2015 | 09:50 PM
i guess i mean i want to mod and upgrade it its clean it drives fine but it needs to be patched up
i live in Rhode Island do you know of anyone that is good with these cars or any shops i need to make a plan so i dont waste money this is my first audi car i like it i just dont want to go broke and have no car
Old May 19, 2015 | 09:51 PM
Sorry, I don't know anyone reputable in the Rhode Island area to recommend. Maybe someone else on the forums are from that area and can recommend a good body shop.
However, if you're taking it to a shop for repairs, I don't think this is a job that's going to be done for less than 2000. I believe all in on the A4 that I recently did it was about 1200 in parts alone, and the damage was very similar to what I see in that picture.
Nick92
Jun 29, 2015 10:52 PM
3Audi3Dubs
Dec 14, 2012 07:05 PM
nepaudi
Jan 19, 2010 12:09 AM
blondie
Mar 8, 2008 11:22 PM
blondie
Mar 7, 2008 01:17 PM
