1999 2.4 auto A6 se - Starting Problem
Old May 8, 2007 | 05:11 PM
Seancat's Avatar
Default 1999 2.4 auto A6 se - Starting Problem
Hi all, I am very new to this to bear with me.
I have the above vehicle that does not start in the morning. The engine will turn over briskley but take foe ever to fire. with constant cranking the engine eventually picks up enough momentum to start. It would appear that there is little/no fuel getting through but you can smell the fuel strongly.
Any ideas/ Suggestions?
Regards
Sean
Old May 8, 2007 | 05:20 PM
techbod's Avatar
Default RE: 1999 2.4 auto A6 se - Starting Problem
change the spark plugs or re-gap them for starters then see how it goes
Old May 8, 2007 | 05:25 PM
Seancat's Avatar
Many thanks Dave I will try just that.
I have heard that these vehicles suffer with a fuel pump problem, is this correct?
Regards
Sean
Old May 9, 2007 | 02:44 AM
SSn's Avatar
SSn
I would not say so, about the pump.
Right, first you do is change basic: plugs, air filter, fuel filter.
Then look deeper. You can test fuel pressure, if you think it's that. Also scan it for engine codes, that might be some bad engine controll sensor %) Also Faulty air flow meter etc,
Luiggi
Dec 29, 2014 07:31 PM
swankychris
Nov 28, 2010 09:51 AM
BioRebel
Mar 12, 2009 01:18 PM
mirak
Feb 10, 2008 03:02 PM
havercamp
Jan 29, 2006 06:35 PM
