1st Time Buying an Audi
Old Jul 27, 2014 | 05:27 PM
jra's Avatar
jra
Default 1st Time Buying an Audi
Looking to buy my first Audi (girlfriend already has one that I drive every now and then...) In particular, there is a 2006 Audi A6 Quattro 3.2 that I have my eye on. It has 114,000 miles, navigation, the works; and it seems to be in excellent condition.
What should I be looking for? I'm no car-illiterate, but definitely no mechanic, especially an Audi expert.
What are common things for an A6 of this age and mileage that tend to be problems or concerns? Are there certain repairs/replacements that should be done given the age and mileage?
Thanks in advance.
Edit: I posted in the general forums before I found this category. Please someone delete the other thread, thanks.
Old Jul 27, 2014 | 06:41 PM
Kevin's Avatar
Take a look at what happened to my 05 4.2 at the 130,000 mile mark. I decided to sell mine and am currently waiting for my 2015 A6 TDI to arrive at the dealer on August 11th. As you can see I am the original owner and the car was meticulously maintained.
Miles Service
884 Miles Warranty
1) MMI hardware replaced
5,283 Miles Warranty
1) 5,000 mile service
10,152 Miles $126.53
1) Oil Change
14,775 Miles Warranty
1) 15,000 mile service
2) tighten front passenger seat
3) tighten air vent outlets
4) update airbag software
5) tighten dashboard
6) update MMI software
20,059 Miles $112.74
1) Oil Change
2) tighten dashboard
20,685 Miles Warranty
1) Replaced pollen filter door
2) Replace tire pressure sensor
3) Replace Mmi control ****
24,727 Miles Warranty
1) 25,000 mile service
3) replace windshield wiper blades
28,506 Miles $204.97
1) Brake fluid flush
2) Repair front passenger seat frame
3) Replace license plate light bulb
4) Update MMI software
5) Repair ski sack
6) oil change
28,620 Miles Warranty
1) Replace all 8 coil packs
2) Replace throttle control valve
29,806 Miles Warranty
1) replace fuel door cover
2) update airbag software
32,254 Miles Warranty
1) Replace front brake pads
2) clean HVAC drains
3) replace pollen filter
33,926 Miles Warranty
1) Replace rear brake pads
2) Replace fuel filter
3) Lube steering column
4) Tighten dashboard
5) 35,000 mile service
36,129 Miles Warranty
1) Update fuel gauge software
2) Replaced power steering hose clamp
36,739 Miles Warranty
1) Replace interior light in driver's footwell
37,715 Miles Warranty
1) Update airbag software
40,759 Miles Combination Warranty/$341.74
1) Transmission fluid flush
2) Replace fluids in differentials
3) oil change
44,754 Miles Warranty
1) Replace steering column
2) convert front brake pads
3) 45,000 mile service
49,419 Miles Warranty
1) Replace head cover gasket
2) Oil Change
50,283 Miles Warranty
1) Replaced rear sunshade motor
54,659 Miles combination warranty/$891.32
1) coolant system flush
2) replace coolant temperature sensor
3) replace fog lamp
4) replace trunk latch
5) 55,000 mile service
56,440 Miles combination warranty/$110.29
1) update ECU module
2) replace tire air pressure sensors
3) replace windshield wipers
60,168 Miles combination warranty/$241.49
1) oil change
2) brake fluid flush
3) replace rear seat air bag ignitor
61,040 Miles $1,186.67
1) replace front brake pads and rotors
2) replace rear brake pads and rotors
65,209 Miles combination warranty/$323.54
1) 65,000 mile service
3) replace parktronic speaker
65,635 Miles $435.50
1) replace thermostat
66,553 Miles $168.85
1) Replace light bar in front passenger door
66,848 Miles $268.20
1) Replace wood trim on driver's front door
69,020 Miles $123.55
1) Oil change
70,741 Miles $287.34
1) Replace rear right tail light assembly
2) Clear air bag codes
75,099 Miles $761.88
1) 75,000 mile service
75,762 Miles Warranty
1) replace center rear seat air bag sensor
2) replace rear seat bracket
80,187 Miles $1,223.61
1) oil change
2) flush transmission fluid
3) replace brake fluid
85,450 Miles $320.44
1) 85,000 mile service
87,879 Miles Warranty
1) replace rear seat air bag sensor connector
2) readapt tilt wheel steering column
90,746 Miles $826.97
1) oil change
2) replace oil pressure sensor
3) re-adapt steering column
4) replace rear brake pads and rotors
93,793 Miles combination warranty/$315.09
2) replace front brake pads
95,964 Miles $720.33
1) 95,000 mile service
2) replace battery
100,600 Miles $1,529.52
1) oil change
2) replace all 8 coil packs
3) replace fuel filter
4) replace brake fluid
5) coolant flush
6) replace supplemental rear passenger air bag
103,924 Miles $1,191.74
1) 105,000 mile service
2) replace passenger tailight assembly
3) replace right side motor mount
110,515 Miles $2,277.12
1) oil change
2) replace all 4 upper and lower control arms and tie rod ends
3) replace both side sway bar links
115,704 Miles $861.73
1) 115,000 mile service
2) 4 wheel alignment
3) replaced left side license plate bulb
4) replaced passenger side running light
120,490 Miles $1,105.50
1) oil change
2) replace transmission fluid
3) replace differential fluids
124,683 Miles $2,303.08
1) 125,000 mile service
2) replaced front brake pads and rotors
3) replaced rear brake pads
4) replaced satellite radio module
5) replaced battery
127,496 Miles $552.87
1) replaced rear passenger window regulator
2) replace passenger sider amber light bulb
133,383 Miles $1,516.17
1) replace jet pump valve
2) replace engine temperature sensor
3) replace both radiator hoses
4) coolant flush
5) brake fluid flush
6) 135,000 mile service
133,600 Miles combination warranty?$502.96
1) replace right side combi valve
2) replace passenger side adaptive headlight assembly
133,714 Miles $225.52
1) fuel injection service
134,585 Miles $1,977.74
1) replace vacuum line under manifold
2) replace temperature sensor
3) replace driver side adaptive headlight assembly
135,880 Miles $493.54
1) replaced thermostat
2) bled coolant system
3) replaced rear passenger side seat latch
137,015 Miles $1,540.46
1) replace drivers air bag
2) replace wiper blades
138,250 Miles $849.93
1) replaced radiator
138,682 Miles $9,116
1) oil change
2) replace torque converter
3) replace timing chains
4) replace timing chain guides
5) replace timing chain tensioners
138,939 Miles Warranty
1) replace intake manifold
2) replace all coil packs
3) replace all fuel injectors
4) replace fuel distributor rail
5) replace front heated oxygen sensor
6) replace combi-valve
Old Jul 28, 2014 | 12:36 AM
jra's Avatar
jra
Thank you! That information is invaluable!
Are you saying I shouldn't get this A6 then?
Old Jul 28, 2014 | 06:21 AM
Kevin's Avatar
They are a lot of fun. However, they can get expensive in a hurry.
Old Jul 31, 2014 | 11:16 AM
ppgoal's Avatar
I can't speak for the newer A6s, but I had no where that much work done and have 231k on mine.
Kevin, did I read in another post that you drive in the NYC area. I go through there regularly for work and to visit family in CT, and I dread every trip. The roads suck, pot holes are everywhere, as well as depressed storm drains. My suspension and vehicle in general take a beating. No wonder you had so much loose $hit that had to be tightened. :-)
Old Jul 31, 2014 | 08:10 PM
Kevin's Avatar
Long Island roads can be tough.
Old Aug 3, 2014 | 09:24 AM
billminpa's Avatar
I have a 2014 A-6 TDI and love everything about it except fueling it
Old Aug 3, 2014 | 09:41 AM
Kevin's Avatar
My 2015 A6 TDI Prestige is in the Port. Should be at the dealer in a week! Can't wait.
audicus
Aug 10, 2014 04:36 PM
hangten93
Jan 28, 2009 12:19 AM
northcheels
Oct 30, 2007 09:20 PM
kamil212
May 1, 2007 01:42 PM
Nett
Aug 25, 2005 10:44 PM
