2.7t upgrade under way
Old Sep 1, 2008 | 10:27 PM
nothing77's Avatar
Default 2.7t upgrade under way
Getting ready to pull the a6's engine next week, it will be going under the knife and getting a new TC and upgraded valve bodies, considering swapping steering wheel and self cancelling ring at the same time so I can have some paddle shifters. I plan on pulling most accessories off the top and polishing whatever I can get my hands on. I am going with VAST performance products for the TC and level 10 for the valve bodies. After I added the water/meth kit the TC began to slip at high RPM and under full boost, I always knew it was going to happen. Now it's time to take care of things before I get my full stage 3 custom tune from VAST. I will let you know how things work out.
Cheers
Ryan
Old Sep 2, 2008 | 07:14 AM
katcoota's Avatar
Sounds great. Good luck with it all. Post some pics...
Old Sep 2, 2008 | 07:42 AM
wammy18's Avatar
How much for the work? I will need this aswell shortly
Old Sep 2, 2008 | 08:20 AM
nothing77's Avatar
work will be done by me, so zero dollars labor, total on parts should run about 2k, it may end up being a little more if I find things worn that need replacing
Old Sep 2, 2008 | 05:09 PM
wammy18's Avatar
that isn't to bad.. damn where are you located maybe I could pay you for my job ;P or might get audi to do it
wammy18's Avatar
nm Calgary Alberta
Audi=Happiness
Apr 30, 2008 01:57 PM
stromo
Apr 23, 2008 07:21 PM
auditt225
Jul 20, 2007 03:56 PM
BadLuckAudi
Oct 14, 2005 02:30 AM
Dudek12
Oct 13, 2005 12:44 AM
