2000 2.7t codes
Old Apr 13, 2007 | 04:03 PM
cengiz's Avatar
Default 2000 2.7t codes
hey whats up ihave a2000 a6 2.7t my check engine light turned on i was wandering if anyone new what they where 1 one is p1423 manufacturer contrl auxiliary emisssion control. 2 is p1411 manufacturer contrl auxiliary emission. 3is p0741 torque converter ckt performance or stuck off. thank you for your help
Old Apr 13, 2007 | 11:32 PM
mpw2.7T's Avatar
Default RE: 2000 2.7t codes
P1423
17831
Sec. Air Inj.Sys.,Bank 1
Flow too low 2)
- Check fuse for secondary air injection pump
- Check vacuum hoses
- Check piping from pump to secondary air injection valve (combi valve)
Repair Manual, 2.7 Liter V6 5V BiTurbo Engine Mechanical, Engine Code(s): APB, BEL, Repair Group 26; Secondary air injection system
P1411
17819
Sec. Air Inj.Sys.,Bank 2
Flow too low 2)
- Check fuse for secondary air injection pump.
VAG 1551 scan tool print out
Possible cause of malfunction
Corrective action
17125 P0741
ATF level not OK or incorrect torque converter installed
- Check ATF level
Repair Manual, Automatic Transmission 01L, Repair Group 37
- Check torque converter code
Clutch for torque converter connection
No power transfer
Continuation
Pressure Control Valve -N218 mechanically faulty
Problems with ATF supply to Pressure Control Valve -N218
Torque converter pressure pressure valve faulty.
Torque converter clutch valve faulty.
- Read measuring value block page 01-120 ; display group number 007 and check permissible converter slippage.
- Replace Pressure Control Valve N218 or replace valve body if necessary.
Repair Manual, Automatic Transmission 01L, Repair Group 38
Continuation
[hr]
[align=right]01-71[/align][/align]
Corrective action
Continuation for DTC
17125 P0741
Clutch for torque converter faulty or worn
- If necessary replace torque converter.
Repair Manual, Automatic Transmission 01L, Repair Group 32
No power transfer
Electrical activation of Pressure Control Valve -N218 faulty
- Perform corrective action according to DTC code number 18237/P1829 or 18238/P1830
Note for DTC 17125 / P0741:
The ratio between transmission input RPM (-G182) and engine RPM with engaged converter clutch does not make sense (implausible). [/align]
Old Apr 14, 2007 | 04:48 PM
cengiz's Avatar
Old Mar 31, 2008 | 02:12 PM
ditallow's Avatar
Hey i have the same problem with my car now. I have the same exact 3 codes. I replaced my secondary air pump. And checked hoses. Still the same. And for the torque converter. Did you happen to change it or did you find another solution for the torque converter code?
TheFrostyArab
Sep 5, 2012 04:40 PM
isleblue65
Oct 14, 2011 06:42 PM
Leeet
Aug 1, 2011 05:02 PM
aarono_120
May 8, 2010 11:36 PM
olle
Mar 18, 2009 12:27 PM
