2000 S4 very slow... no codes.
Old Jul 29, 2011 | 11:22 PM
Leeet's Avatar
Exclamation 2000 S4 very slow... no codes.
I just recently purchased my first Audi. It's a 2000 S4 6 speed with low miles. The problem is that it has very poor acceleration. And by poor acceleration I mean a Toyota Prius would blow the doors off of this s4. It runs and drives great other than that. It idles smoothly. I can hear the turbos spool at low RPMs (well I can hear at least 1 turbo, not sure if it's both). The check engine light isn't on, but I scanned for codes anyway; came up with nothing.
One thing I did notice was that the hood/fenders of the car were very hot after a 30min drive. However, the temperature gauge & oil temp gauge were reading normal. I also noticed that the exhaust fumes seemed hotter than they should be.
Does anybody have any ideas as to what the problem could be? Thank you in advance for any help.
Old Jul 31, 2011 | 04:57 PM
FonzoB5S4's Avatar
do the rpms go crazy high when you accelerate but the car takes off really slow?
Old Jul 31, 2011 | 11:27 PM
bigern45's Avatar
tbb ripped
Old Aug 1, 2011 | 12:06 AM
Leeet's Avatar
No, I don't think the RPMs shoot up any faster than they should. Are you thinking maybe the clutch is slipping? Because the clutch seems to be in good condition. Granted this is the first audi I've ever driven (or even sat in), so I may be wrong about the RPMs going up at normal speed. I've always driven & worked on muscle cars my whole life. I purchased this car for the winter.
Old Aug 1, 2011 | 12:08 AM
Leeet's Avatar
Originally Posted by bigern45
tbb ripped
I just did some quick research on this. Apparently the TBB is prone to ripping in the 2.7T? I'll have to check out the TBB on the car tomorrow.
Old Aug 1, 2011 | 02:46 AM
FonzoB5S4's Avatar
i was thinking more of a boost leak. a tbb tear would be a boost leak. yo might wanna do a boost leak test. do your diverter valves look ok? are the diaphragms torn?
Old Aug 1, 2011 | 03:38 AM
Leeet's Avatar
Well I checked the TBB and f-hose; no rips. Checked all the hoses that I could see; nothing.
However I did find that the y pipe had a hole on the bottom of it at some point, and repaired with silicone & duct tape. It seemed to be sealed pretty well, but I'm going to get a boost leak tester to make sure. Some of the lines running to the diverter valves seemed pretty rough too. Does anybody know where I can pick up a boost leak tester? Or would it just be easier to get one online?
Old Aug 1, 2011 | 05:02 PM
FonzoB5S4's Avatar
isleblue65
Oct 14, 2011 06:42 PM
aarono_120
May 8, 2010 11:36 PM
olle
Mar 18, 2009 12:27 PM
cengiz
Mar 31, 2008 02:12 PM
kwsmithphoto
Nov 25, 2007 01:53 AM
