2000 A6 2.7T w/ NO low beams!
Old Oct 22, 2012 | 12:33 PM
Big Tone's Avatar
Default 2000 A6 2.7T w/ NO low beams!
Hi, all. I've been doing some research and am confused on the solution. My low beams on my 2000 A6 aren't working consistently. Sometimes they both come on, sometimes only one comes on or, like this morning, NEITHER came on! It appears that there is one of two solutions to correct this, but I'm not sure which one. Do I need to replace the headlight switch or is it the turn signal switch? I'd like to order the part today, so if anyone can help me out I'd greatly appreciate it! I'd hate to buy the wrong part and have to wait even longer to correct this. Thanks in advance!
Old Oct 22, 2012 | 12:50 PM
ManyAudis's Avatar
It is probably the multifunction switch on the column. You need to replace the entire assembly. I had this problem on my 1995 S6 and replaced it with a used one I purchased from an Audi forum member. I also learned where the problem was and how to fix it but the fix does not last.
Old Oct 22, 2012 | 01:29 PM
Big Tone's Avatar
Thanks for the info. Is there anywhere I can find instructions on how to remove the old one? I can't find a tutorial on it anywhere.
Old Oct 22, 2012 | 08:06 PM
ManyAudis's Avatar
Unfortunately I do not know how to remove the switch in the C5 body style. Based on my experience with the C4 chassis my guess is that you disconnect the battery and wait 15 minutes to allow the airbag system to completely shut down. Then remove the airbag from the steering wheel and remove the steering wheel carefully making sure that you do not damage the clock spring, disconnect any connectors. Next remove the covers from the steering column and you should see the screws which hold on the multifunction switch.
Old Oct 23, 2012 | 01:25 PM
Big Tone's Avatar
Wow. Looks like I'll be taking the car to the shop. LOL
Old Oct 24, 2012 | 07:45 PM
ManyAudis's Avatar
It is not that bad. The first time is slow but once I did it a couple of times I could remove the multifunction switch in about 15 minutes.
josh_easlon
Feb 1, 2010 01:37 AM
rockblock
Oct 25, 2009 07:13 PM
listentodabeat
Jul 7, 2008 12:56 PM
zchb9
Oct 26, 2007 07:33 PM
Skip Berry
Jan 20, 2005 07:47 PM
