2000 A6 2.8 surging at idle - lots of codes - which one to start with
Old Dec 2, 2013 | 02:55 PM
blockp's Avatar
Default 2000 A6 2.8 surging at idle - lots of codes - which one to start with
Car has 325k miles on it. A week ago driving in heavy rain, it hiccuped a few times and threw a code for crankshaft position sensor. Changed that and it ran flawlessly for a week (70-100 miles per day) with no other codes. Friday, driving on the highway with cruise on, was running fine; disengaged the cruise and exited the hwy. Car died at the bottom of ramp. It started right back up, but now with CEL and idle surge. Have to use the gas pedal to keep it from stalling. Runs fine as long as your foot is on the gas pedal. Drove it 60 miles home like this and pulled codes, cleared them, restarted the car and pulled them again.
I have an exhaust leak at the flex pipe that I have scheduled to get fixed this week and it seemed to get worse over the last week. I can't see how that would cause some of these codes tho.
<Edit>
I have an extra known good ECM for the car. I cleared codes, swapped ECM, restarted and re-pulled codes. Output was the same list of codes as below.
</Edit>
Below are the codes coming from vagcom. I can't believe all of these things happened at the same time while driving with the cruise on. So which one is causing the others?
Any input on this is welcomed. Thanks!
8 Faults Found:
3 - EVAP Purge Valve (N80): Short to Ground
P1425 -- 35-00 - -
4 - Secondary Air Pump Relay (J299): Electrical Malfunction
P1436 -- 35-00 - -
1 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
P1543 -- 35-00 - -
P1425 -- 35-00 - -
7 - Camshaft Timing Adjustment: Short to Plus
P1529 -- 35-00 - -
4 - Fuel Trim Air; Bank 2 (Add): System too Lean
P1126 -- 35-00 - -
9 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 -- 35-00 - -
2 - Ignition Coil Power Output Stage 2: Short to Plus
P1344 -- 35-00 - -
Old Dec 9, 2013 | 11:42 PM
toolagit2qwit's Avatar
Could be your fuel relay switch going. This could trigger these codes. Part pricing ranges from$30-$60. Relay #372. Located under steering left side. You need to remove a few screws to access. YouTube it. Similar for A4 models too
Old Dec 9, 2013 | 11:45 PM
Also check your vacuum hoses. Clean the Mass Air Flow sensor. Also, you may want to change your fuel filter. I would start with vacuum hoses, MAF, fuel pump then relay switch. Just my thoughts.
gappel
Jan 1, 2018 02:41 PM
johnatl_1
Nov 20, 2013 07:45 PM
U's Audi
Feb 19, 2013 09:02 PM
kotabmx
Dec 21, 2007 07:20 PM
LampyB
Apr 19, 2007 05:32 PM
