2000 A6 4.2 rear brake pad replacement problem
Old Oct 9, 2005 | 03:40 AM
ravtech's Avatar
Default 2000 A6 4.2 rear brake pad replacement problem
I have a 2000 A6 4.2 and I'm trying to replace the rear pads but I can't get the rear pistons to retract. I tried rotating the piston clockwise but it just spins and I don't know anyone who has a tool to borrow. I've heard it is necessary to press on the piston while turning but that didn't work (or I can't push hard enough while turning). Any suggestions of how to do this with standard shop tools or recommendations as to where to buy the tool?
Old Oct 13, 2005 | 09:04 AM
98silverstreak's Avatar
Default RE: 2000 A6 4.2 rear brake pad replacement problem
TRY: http://www.ecstuning.com/stage/edpd/...&engine=V6+30v
Old Oct 14, 2005 | 02:01 PM
misko's Avatar
Have you tried to rent the tool at AutoZone
Old Aug 19, 2007 | 09:19 PM
johnnya6's Avatar
I went to auto zone after $%^&ing around with it for an hour and put a $36 deposit (fully refundable)down on the tool and it took me about5 minutes to do it with the right tool, you do have to turn them while compressing them back in and the too worked like a dream. Once I had the tool it was back to taking longer to get the wheel off then changing the brakes just like it should.
Old Aug 22, 2007 | 06:10 AM
namymark's Avatar
Is there a step by step instruction for replacing the rear brake pads? Particularly a 4.2.
Old Aug 23, 2007 | 01:16 AM
Cmoney's Avatar
Hey, I just changed my rear brakes and rotors. That was the first time I had actually done a brake job and it was pretty easy. Here is a link for a brake change on an A8. Our A6's have the exact same set up, well my 2000 2.7 does anyway. Good luckhttp://www.audipages.com/Tech_Articl...earbrakes.html
Old Sep 2, 2007 | 11:50 PM
mactooltom's Avatar
I have the tool in mybox....I will loan ya.
flippu10
Oct 2, 2010 12:02 PM
patchelect
Jun 28, 2009 03:35 PM
motorwerks1
Feb 21, 2009 02:03 PM
cbg
Feb 29, 2008 01:29 AM
modset
Jan 13, 2007 03:37 AM
