2001 2.8 window motor
Old Nov 23, 2006 | 02:52 AM
Boston_A6's Avatar
Default 2001 2.8 window motor
I just bought a 2001 2.8 and have had it back to the dealer twice to fix the drivers window (it slows down when closing and sometimes stops then re-opens). the first time they sprayed the weather striping w/ silicone...it still got stuck but now it was greasy and stuck, next they replaced the motor...it works a little better but doesn't always make it all the way up. Does anyone know what the problem might be so I can point them in the right direction?
Old Nov 23, 2006 | 02:59 PM
SouthboroAudiGuy's Avatar
Default RE: 2001 2.8 window motor
Clearly not an Audi dealer you're going to... (if it is, it's a TERRIBLE one). The window guides wear out - fairly common problem. As these parts wear out, friction goes up. This triggers the pinch sensors which cause the window to retract. Replace the guides and you're good to go. Search the tech articles on www.audiworld.com for a DIY article on this.
Old Nov 24, 2006 | 07:31 AM
Boston_A6's Avatar
yea, this is a warranty issue.... local used car hacks
mrocke440
Nov 20, 2010 09:11 PM
blu.suede
Nov 20, 2010 03:15 PM
Drfeelgood69247
May 22, 2008 06:24 PM
danieltt
May 8, 2008 03:48 PM
JewbinTT
Sep 24, 2007 09:31 PM
