2001 A6 2.7T Start issues
I need some help fellas, My wife has been driving her 2001 A6 2.7T with 106,000 miles on it. She was having trouble starting it while cold so I checked the battery and replaced it. This morning it would not start, it would turn-over and catch for about 2 seconds then quit. after about 5 minutes of this it finally idled and until it warmed up a little when ever I would hit the gas it would sputter. I turned it off after it warmed up a little and re-started like a champ no problems. I have no ideas as to what it could be at this point does anyone have any suggestions.
-all help is appreciated in advanced
It only does this on the first start of the day, after its been started it starts right up. Its not ice in the lines because its not that cold and its garaged, but could it be the coil packs or ICM...I dont have the VAG COM so Im SOL on the codes until atleast Tuesday.
You really need to get it hooked up to a vagcom so that we can get the full story. But the basic gist of a P0177 is that you are having an issue with the fuel air mixture, usually on the fuel side. Could be bad injectors, bad fuel pump, MAF, vacuum leaks, problem with the fuel lines...and on and on. You get the idea.
OK guys I am pleased to announce that it was a $20 part at NAPA Auto Parts the coolant temp sensor. too bad it was after I spent $310 on a fuel pump..Moral of the story for me was to VAGCOM it before I decide to start troubleshooting from the hip....Thanks for all the help Fellas...now since my wife didnt tell me how bad her car was riding I have to buy tires because she rode with her upper and lower arms WORE OUT!!!....so heres another $650..gotta love it
