2001 a6 quattro oil sensor
Old Aug 7, 2011 | 01:03 PM
hilbertp's Avatar
Default 2001 a6 quattro oil sensor
Where abouts is the oil pressure sensor on my Audi? I need to replace it. Is this something I can do myself?
thankyou pete
Old Aug 7, 2011 | 02:24 PM
TomKat's Avatar
Default Good Luck
I had a problem with the low oil pressure warning light coming on - hoped it was the switch.
I asked the same question, when no none replyed I started my in car search.
It is actually behind the oil filter housing, very difficult to see.
I jacked the front way up and could just see the wire going to it.
Remove the oil filter and while you may not see it, you can reach in to disconnect the wire (push down on tab and pull)
From there you can get a deep socket on it (21mm I believe).
Break it loose and remove by hand.
Reverse for install.
It did the trick for me, no more flashing lights and sounds
Good Luck
Old Aug 8, 2011 | 02:12 PM
hilbertp's Avatar
Default thankyou Tomkat
Not sure how to replay and say thanks to Tomkat for the info. I will give it a try!
peter
Old Aug 10, 2011 | 12:39 PM
TomKat's Avatar
Default You are Welcome
Good Luck...
I hope it is just the switch, it usually is.
Old Sep 19, 2011 | 03:39 PM
hilbertp's Avatar
TomKat, where did you buy your sensor from?
By the way I got the electrical connection off so all I need is the deep socket and part!
Old Sep 20, 2011 | 06:44 PM
TomKat's Avatar
Default Dealer = $$$
I got mine from the dealer for $30.38.
You can get one from RockAuto.com for as low as $3.41, however I would go with the $9.40 one made by Beck/Arnley.
I think you can also find them at Pep boys and Autozone.
Once you get it, check the socket size.
I assume you won't pull it until you get a replacement, it makes a mess when you drive without it
Old Sep 21, 2011 | 04:45 PM
hilbertp's Avatar
The dealer cost for mine is 24$+tax, this is where i never am sure if buying from these other sources is as good as product.
thx pete
Old Sep 23, 2011 | 07:50 PM
TomKat's Avatar
Default Go with the dealer
That's a better price than I paid.
I bought the Audi part because I thought it would be better quality...
However, my son reminded me that the OEM one failed, maybe I should get another manufacturer... Good Point!
I just wasn't sure which aftermarket ones would be coming from China.
I thought I would stick with the German product (I'm hoping they're not made in China also)
Good luck
Old Sep 24, 2011 | 01:27 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
I'm showing that oil pressure switch to be 06A-919-081-J and we sell it for 15.19 plus shipping with either UPS or usps on our website. We have 2 in stock if you need one. Thanks, Jeff.
ZombieDolly
Nov 4, 2012 12:54 AM
bcc2481
Jul 12, 2011 07:01 PM
rehan1212
Apr 23, 2010 11:07 AM
Thumper
Mar 14, 2007 10:12 PM
