2001 AUDI A6 2.8 fwd transmission issue
Old Nov 10, 2010 | 10:16 PM
budhani786's Avatar
Default 2001 AUDI A6 2.8 fwd transmission issue
the transmission is dropping gears slower than usual. when the car is moving and i brake hard the down shifts take longer to happen so when the car has stopped the transmission is still in second gear for 2 sec and then back to 1st. but this is only happening when hard braking is applied.
any suggestions?? ALL HELP IS APPRECIATED! THANKS! if need more info please say so.
the car has 80k on the dot transmission oil replaced along w/ gasket
also the transmission acts weird on 3rd to 4th after it goes into 4th the rpm needle goes down once a little and (the car is still accelerating) and it goes down again. is it slipping? will a software update fix these problems?
thanks for taking the time. ALL SUGGESTIONS ARE GREATLY APPRECIATED! THANKS
Old Nov 11, 2010 | 11:11 AM
bob martin's Avatar
I would double check the transmission fluid level as it sounds like the fluid is a bit low. Other possible faults are expensive.
Good luck,
Bob
Audia4turbo323
May 31, 2015 04:25 AM
c_zellars
Feb 27, 2014 02:58 PM
AlienA6
Oct 10, 2010 02:55 PM
sancherv
Mar 23, 2009 08:09 PM
cgaffney004
Mar 2, 2006 11:39 AM
