2002 A6 4.2 Oil change Synethic every 10k?
Old Aug 29, 2012 | 04:52 PM
daboss085's Avatar
Default 2002 A6 4.2 Oil change Synethic every 10k?
Can someone tell me if doing a synthetic oil change on this car would be once a year every 10k? A European specialist in European cars told me this and it costs 105 dollars for the oil change. Thanks guys..
Old Aug 29, 2012 | 07:29 PM
sheldon's Avatar
I replace my oil every 3-5k (synthetic) to keep the car running smooth. I think however if you are a non aggressive driver 10k or once every year (which ever comes first) is possible but I would not recommend it. And yes an oil change is expensive on our V8s .. it takes 8 quarts + fresh oil filter. If you do it yourself it will run you about 70$.
Old Aug 30, 2012 | 10:40 AM
sttrebo's Avatar
on my '03 4.2 I usually stick with about 7500iles between changes. keeps the oil from getting too dark.
Old Aug 30, 2012 | 05:52 PM
z28pete's Avatar
Apparently Audi does not want the engines to last too long. I definitely would not go past 5000 miles, unless it was all interstate cruising. Changing oil every 10,000 miles is OK if you plan to change the car every year, and let the next owner worry about it. The oil itself does not wear out, but all the dirt, grime, and especially sludge that is going to bypass the filter after it clogs up, is going to slowly chew up the engine. Some of the newer VW/Audi engines have been having oiling problems caused by sludge resulting from long oil change intervals combined by inadequate engine design. If you don't see paying $100 for an oil change, do your own. Go to your local Wallmart and pick up two 5 quart jugs of Mobil1 for about $30 each and a Bosch filter for $10 and you will have an extra 2 quarts to use later.
Old Aug 30, 2012 | 08:45 PM
budhani786's Avatar
X2
I would not run 10k on my car. I change the oil every 5k.
If you do a lot of city driving then I would change it earlier. Fuel gets into the oil from Lots of cold starts and weakens the TBN and viscosity.
I would say 7k is OK If the car is doing hwy driving.
Big Don
Nov 18, 2012 04:52 PM
scanny1
Mar 3, 2012 03:14 PM
topj
Jan 19, 2008 06:15 AM
mbtbon
Jul 18, 2007 06:45 PM
bolsen
Sep 25, 2005 02:15 AM
