2003 (3.0 avk) catalytic converter help
Old Dec 17, 2008 | 10:04 PM
Spookem's Avatar
Exclamation 2003 (3.0 avk) catalytic converter help
I need some input on how to go about removing the catalytic converter on my 2003 Audi A6 3.0 Quattro. I have recently replaced the motor in the car and of course in the process I failed to clean out the flange bellows in front of the Cat, i.e. debris from the old exploded motor. I am asking advice on the easiest way to replace the Cat without pulling the motor. Any intellectual advice would be greatly appreciated.
Thank you gentlemen
Old Dec 18, 2008 | 12:29 AM
auditech79's Avatar
You can get them out by dropping the bolts out of the rear subframe and loosening the front subframe bolts. Once the tranny is hanging down enough for you to clear the cats past the trans then you can use a 13mm gear wrench and take out the three bolts. The Single top bolt has to be done from above the motor, taking out the airbox for the passenger's side, and removing the two cam sensors on the drivers side is required.
Old Dec 18, 2008 | 02:38 PM
Spookem's Avatar
Default Sweet its easier than I had anticipated..
Well I guess its always easier said then done but overall that doesnt sound to terribly difficult. One more quick question, if I do find the cat to be broken or dammaged is there a universal replacement one that will act close to an oem equal? I really dont want to pay the five hundred or so dollars the dealership wants for their "AUDI" catalitic.
Thank you sir for the quick response on my previous post!
Old Dec 18, 2008 | 05:41 PM
auditech79's Avatar
$500, LOL, try $1,000 per cat. The only thing you can do is take out the cat/downpipe and have an exhaust shop cut the cats out of the old downpipes, and weld in universal ones, then have them weld in an after cat O2 sensor connection piece.
Old Oct 19, 2020 | 02:09 PM
Kaedened's Avatar
Default Update?
how did it go sir
DanaB6
Sep 25, 2010 09:42 AM
707782y
Sep 22, 2007 04:37 AM
myredaudia4
Apr 25, 2007 11:22 AM
myredaudia4
dragondesigns
Mar 30, 2006 02:35 AM
