2003 3.0L Smog pump troubleshooting
There is a couple of threads on smog/air pumps.
I have the code for the air pump, but I dont have the vacuum cleaner noise
what is he best way to troubleshoot the pump
JPJMustang
JPJMustang
You can disconnect the wiring harness from the pump and then apply a constant 12v to the pump to see if it turns on. You'll be able to hear it / feel it turn on when you do this. If you don't, you know that your pump is not working completely.
Are you getting error codes that state insufficient flow to banks 1 and 2?
I asked because if it was just one bank, then it may not be the pump that is at fault. I'm willing to bet that your secondary air pump completely failed. Which is odd because usually when they're on their way out you hear it.
