2005 A6 front side marker light changing
Old Jun 7, 2009 | 09:13 PM
ncarvain's Avatar
Default 2005 A6 front side marker light changing
There has to be a way to change this light without taking the car to the dealership. Anybody have any experience changing the front side marker light.
Thanks
Nick
Old Jun 7, 2009 | 10:41 PM
Jackmup's Avatar
wrap a rag around a screwdriver and pry it out start at the front not the back go easy not to chip the paint. but they pop right out.
Old Jun 11, 2009 | 08:55 PM
ncarvain's Avatar
There has to be a better way. I cant even see getting the screwdriver in with a towel wrapped around it, there is like no space. Please help!!
Old Jun 11, 2009 | 09:32 PM
Jackmup's Avatar
I used a red shop rag so try paper towels the light is held in by a spring as soon as you start to slide it in it will pull out I just replaced all four of my bulbs (2 cars)and they pop right out. If your afraid of the crew driver scatching use a plastic knife with the towel wrapped around it.
By the way I am using a Snap-on carburetor adjuster screwdriver it is small and thin. Not some big clumsy thing for paint cans or anything. If I scatched my car I would have to repaint it right away so I'm totally with you on the scratching. Lights cost $3.00 on ebay per set to replace but they wont break anyway.
The only other thing I can think of is 3M double sided tape it is very adhesive and it might be sticky enough to pull the light out.
Old Jun 16, 2009 | 10:26 PM
ncarvain's Avatar
well I figured it out, and think i have a better way (no offense Jackmup, I appreciate your help =] ) to do it. The light is held in by a spring but it is only on the rear half, not the front half of the light. I went through the front wheel well. There are a couple star bolts that I removed, then loosened the wheel well cover. Put my arm through and pushed out on the light on the rear half. Eventually the spring gives and the light pops out. The front half of the light is a retaining clip, and once the spring gives, you can just remove the light. Seems pretty easy, now that I know how to do it. Any questions, let me know. I took a pic of the light, and will try to post.
Old Jun 17, 2009 | 12:24 AM
Jackmup's Avatar
Glad that you got it done with out scratches.
Old May 5, 2013 | 07:28 PM
ccclabaugh's Avatar
Default Step by step front side marker light change
I elected to remove 3 wheel well screws holding the weather cover to the body. I was then able to reach up into the bumper, find the rear of the light fixture, press firmly and it pops out. Bulb held in with a rubber fitting, apply a bit of leverage from a small flat screwdriver, and then the light is easily removed/reinserted. Reverse procedure to button it up. About 5 minutes in all.
Attached Thumbnails 2005 A6 front side marker light changing-20130505_160911.jpg   2005 A6 front side marker light changing-20130505_160917.jpg   2005 A6 front side marker light changing-20130505_160857.jpg   2005 A6 front side marker light changing-20130505_160932.jpg   2005 A6 front side marker light changing-20130505_161007.jpg
Old Feb 15, 2014 | 02:07 PM
JacksCar's Avatar
Default Quick fix
I had the same question, but worked it out without any scratches or dismantling. I used some good duct tape (REAL duct tape used for actual HVAC work, although standard grey tape might work also) securely stuck to the back of the assembly. Just a very easy pull to the rear end of the lamp assembly and it popped out. Swapped bulbs and was done in less than a minute.
V10wnitrous
May 13, 2013 04:34 PM
chefro
Dec 29, 2010 09:40 PM
Optical Serenity
Nov 18, 2006 10:59 PM
ibe3pac
Jan 26, 2006 09:37 PM
